Threads: 1
05-18-2023, 01:32 PM
Is there a way to use the KC868-A16 Board to directly control an LED using PWM or are all mosfets only controllable using the PCF8574 I/O Expander?
Thank you!
Threads: 1,277
A16 only use for ON/OFF by mosfet, can't output PWM.
Threads: 0
Good day admin, i just received my KC868-A16 board. can i use the same esp home yaml code from my "A16S" to my new "A16"? Is the
pcf8574 address, id of the input and output the same? Please can you correct the code below. thanks.
Smart Home Automation Forum › Technical Support › KC868-A16S
KC868-A16S configure yaml for ESPhome
New Reply Thread Rating:
12345
Threaded Mode
admin Offline
Administrator
platform: ESP32
sda: 4
scl: 5
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
# Optional manual IP
# manual_ip:
# static_ip: 192.168.1.199
# gateway: 192.168.1.1
# subnet: 255.255.255.0
address: 0x24
address: 0x25
address: 0x22
address: 0x23
# Individual outputs
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
pcf8574: pcf8574_hub_out_2
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
pcf8574: pcf8574_hub_in_1
number: 4
number: 5
number: 6
number: 7
pcf8574: pcf8574_hub_in_2
number: 4
number: 5
number: 6
number: 7
Threads: 0
Thank you sir for your help. Newbies like me really appreciate it. =)
