M1-Home assistant.txt (Size: 865 bytes / Downloads: 521)
platform: ESP32
uart:
- id: uart_bus
tx_pin: GPIO13
rx_pin: GPIO14
baud_rate: 9600
stop_bits: 1
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
- platform: bl0942
uart_id: uart_bus
update_interval: 3s
voltage:
current:
filters:
multiply: 0.1965
power:
energy:
frequency:
name: "M1 Frequency"
accuracy_decimals: 2
pin: 33
pin: 32
