06-05-2024, 04:32 AM
friendly_name: e8t-tuya
platformio_options:
board_build.extra_flags:
# WIFI_CONTROL_SELF_MODE = 0
# WIFI_CONTROL_SELF_MODE = 1
platform: ESP32
on_boot: #Power chip BL0939 initialization
priority: 600
then:
- uart.write:
data: [0xA5, 0x39, 0x42, 0x00, 0x00, 0xDF]
- delay: 1ms
- uart.write:
data: [0xA5, 0x38, 0x3C, 0x00, 0x00, 0xE6]
- delay: 1ms
- uart.write:
- delay: 1ms
- uart.write:
data: [0xA5, 0x3A, 0x01, 0x00, 0x00, 0x1F]
- delay: 1ms
- uart.write:
data: [0xA5, 0x39, 0x00, 0x00, 0x00, 0x21]
external_components:
- source:
type: git
ref: v1.1.0
uart:
- id: uart_1
tx_pin: GPIO12
rx_pin: GPIO39
baud_rate: 4800
parity: NONE
stop_bits: 2
# - id: uart_2
# tx_pin: GPIO33
# rx_pin: GPIO36
# baud_rate: 4800
# parity: NONE
# stop_bits: 2
- id: tuya_mcu_uart
tx_pin: GPIO13
rx_pin: GPIO16
baud_rate: 9600
tuya_wifi_mcu:
# tuya mcu product id
product_id: d8vwzka9smrcjznp
uart_id: tuya_mcu_uart
wifi_reset_pin: 28
wifi_led_pin: 16
# baud_rate: 0
ota:
password: "d83d604e4f0ae287fb041dbaf31524d9"
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
- platform: bl0939
uart_id: uart_1
update_interval: 10s
voltage:
current_1:
name: 'BL0939A Current 1'
current_2:
name: 'BL0939A Current 2'
active_power_1:
name: 'BL0939A Active Power 1'
active_power_2:
name: 'BL0939A Active Power 2'
energy_1:
name: 'BL0939A Energy 1'
energy_2:
name: 'BL0939A Energy 2'
energy_total:
name: 'BL0939A Energy Total'
# - platform: bl0939
# uart_id: uart_2
# update_interval: 10s
# voltage:
# name: 'BL0939B Voltage'
# current_1:
# name: 'BL0939B Current 1'
# current_2:
# name: 'BL0939B Current 2'
# active_power_1:
# name: 'BL0939B Active Power 1'
# active_power_2:
# name: 'BL0939B Active Power 2'
# energy_1:
# name: 'BL0939B Energy 1'
# energy_2:
# name: 'BL0939B Energy 2'
# energy_total:
# name: 'BL0939B Energy Total'
sda: 4
scl: 5
address: 0x24
address: 0x22
# Individual outputs
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
- platform: tuya_wifi_mcu
dp_id: 1
# hide from homeassistant ui
internal: true
bind_switch_id: "e8t_output1"
mode: OUTPUT
dp_id: 2
internal: true
bind_switch_id: "e8t_output2"
mode: OUTPUT
dp_id: 3
internal: true
bind_switch_id: "e8t_output3"
mode: OUTPUT
dp_id: 4
internal: true
bind_switch_id: "e8t_output4"
number: 4
mode: OUTPUT
dp_id: 5
internal: true
bind_switch_id: "e8t_output5"
number: 5
mode: OUTPUT
dp_id: 6
internal: true
bind_switch_id: "e8t_output6"
number: 6
mode: OUTPUT
dp_id: 123
internal: true
bind_switch_id: "e8t_output7"
number: 7
mode: OUTPUT
dp_id: 124
internal: true
bind_switch_id: "e8t_output8"
pcf8574: pcf8574_hub_in_1
dp_id: 122
bind_binary_sensor_id: e8t_input1
internal: true
dp_id: 121
bind_binary_sensor_id: e8t_input2
internal: true
dp_id: 120
bind_binary_sensor_id: e8t_input3
internal: true
dp_id: 119
bind_binary_sensor_id: e8t_input4
internal: true
number: 4
dp_id: 118
bind_binary_sensor_id: e8t_input5
internal: true
number: 5
dp_id: 117
bind_binary_sensor_id: e8t_input6
internal: true
number: 6
dp_id: 116
bind_binary_sensor_id: e8t_input7
internal: true
number: 7
dp_id: 115
bind_binary_sensor_id: e8t_input8
internal: true
web_server:
port: 80download yaml file:
KC868-E8T-HA-Tuya.txt (Size: 8.39 KB / Downloads: 503)
