01-20-2026, 09:46 PM
KC868-D16 dimmer controller MQTT configuration for home assistant fixed linear issue
01-20-2026, 11:22 PM
post your yaml file by file at here, not copy and paste text.
01-21-2026, 08:54 AM
The file:
https://www.dropbox.com/scl/fi/9ue47mq3s...1to4b&dl=0 Now, the d16 do not try to connect. exacly the same configuration and network. Thamk you best regards
01-21-2026, 11:12 PM
set your ethernet mode to "DHCP", not use "STATIC", if also can't work , tell me, i will test it.
| 1 Guest(s) |
