09-14-2024, 12:09 AM
Made by KinCony IoT: https://www.kincony.com
All rights reserved.
ESP32-S3 with SIM7600 and RS485 Communication
This program sends an AT command to the SIM7600 4G module every 3 seconds to query its model number.
The response from the SIM7600 is then sent out through the RS485 interface.
Connections:
SIM7600:
TXD: GPIO18
RXD: GPIO17
RS485:
TXD: GPIO9
RXD: GPIO8
#include <HardwareSerial.h>
// Create a hardware serial object for SIM7600 communication using UART2
HardwareSerial sim7600(2); // UART2: TXD on GPIO18, RXD on GPIO17
// Create a hardware serial object for RS485 communication using UART1
HardwareSerial rs485(1); // UART1: TXD on GPIO9, RXD on GPIO8
// Initialize the default serial port for debugging (Serial Monitor)
Serial.begin(115200); // Baud rate of 115200 for debugging
// Initialize the SIM7600 serial port with baud rate of 115200
// Set TX to GPIO18 and RX to GPIO17
sim7600.begin(115200, SERIAL_8N1, 17, 18);
// Initialize the RS485 serial port with baud rate of 9600
// Set TX to GPIO9 and RX to GPIO8
rs485.begin(9600, SERIAL_8N1, 8, 9);
// Wait for 3 seconds before starting (optional, can be used for initialization delay)
delay(3000);
// Send the AT command to query SIM7600 module model number
// "AT+CGMM" is the command used to get the model of the SIM7600
sim7600.println("AT+CGMM");
// Wait for 1 second to allow time for the SIM7600 to respond
delay(1000);
// Check if there is any data available from the SIM7600 module
if (sim7600.available()) {
// Create a string to store the response from the SIM7600
String simResponse = "";
// While data is available from the SIM7600, read it byte by byte
while (sim7600.available()) {
// Read one byte from the SIM7600 serial
char c = sim7600.read();
// Append the byte to the response string
simResponse += c;
// Send the SIM7600 response to the RS485 serial port
rs485.print(simResponse);
// Also print the response to the Serial Monitor for debugging
Serial.println(simResponse);
// Wait for 3 seconds before sending the next query
delay(3000);
10-4g-sim7600.zip (Size: 1.04 KB / Downloads: 522)
10-4g-sim7600.ino.merged.zip (Size: 182.27 KB / Downloads: 531)
