[arduino code examples for A6v3]-04 RS485 communication test
* RS485 Communication Test with Echo
* This program tests RS485 communication using ESP32-S3.
* It sends a message over RS485, reads incoming messages, and echoes them back.
* The TXD pin is defined as GPIO 9 and RXD pin is defined as GPIO 8.
#include <HardwareSerial.h>
// Define RS485 pins
#define RS485_RXD 18
#define RS485_TXD 17
  while (!Serial);
  // Send a test message periodically
// rs485Serial.println("Hello from KinCony A32 Pro!");
  // Wait for a short period
  delay(100);
  // Check if data is available to read from RS485
    String receivedMessage = "";
      char c = rs485Serial.read();
      receivedMessage += c;
    // Print the received message to the serial monitor
    Serial.print("Received: ");
    // Echo the received message back over RS485
    rs485Serial.print("Echo: ");
    rs485Serial.println(receivedMessage);
  delay(2000);
arduino ino file download:
.zip   RS485.zip (Size: 810 bytes / Downloads: 465)
.zip   RS485.ino.merged.zip (Size: 184.34 KB / Downloads: 427)
