[arduino code examples for T16M]-02 Read digital input ports state
* Description:
* This Arduino program reads the state of a 16-channel PCF8575 I/O expander
* and prints the state of all input pins to the Serial Monitor. The state of
* each pin is represented as a bit in a 16-bit value, where each bit corresponds
* to an input pin. The program prints the input state in binary format.
* Pin Definitions:
* - SDA: GPIO 11
* - SCL: GPIO 12
* - PCF8575 I2C Address: 0x24
#include "Arduino.h"
#include "PCF8575.h"
// Define I2C pins
#define I2C_SDA 11  // Define SDA pin
#define I2C_SCL 12  // Define SCL pin
// Set I2C address
PCF8575 pcf8575_IN1(0x24); // The I2C address of the PCF8575
    Wire.begin(I2C_SDA, I2C_SCL); // Initialize I2C with defined SDA and SCL pins
    pcf8575_IN1.begin(); // Initialize the PCF8575
    Serial.println("KinCony F16 16 channel input state 0:ON  1:OFF");
    uint16_t state = 0;
    // Read the state of each pin (assuming 16 pins)
    for (int pin = 0; pin < 16; pin++) {
        if (pcf8575_IN1.read(pin)) {
            state |= (1 << pin); // Set the bit for the active pin
    Serial.print("Input state: ");
    Serial.println(state, BIN); // Print the state of inputs in binary
    delay(500); // Delay 500ms
arduino ino file download:
.zip   2-digital-input.zip (Size: 839 bytes / Downloads: 720)
.zip   2-digital-input.ino.merged.zip (Size: 189.53 KB / Downloads: 723)
