868-A6 Tasmota "Reset"
Hello ! Following Problem....I had to change the System including the Wifi....and I forgot to change the Wifi password earlier....how can I reset the Wifi password ?? I tried the Tasmota way....6 times ON/OFF but was not working ? You have an Idea ??? Thank you
you can re download tasmota firmware to ESP32. then set the wifi ssid and password again.
