Hi guys,
I have PIR sensors all over the house connected to an old alarm system. The voltage on the NO contacts are between 1.5v to 3v, which I think is too low for the digital inputs 1 to 16 to register as ON.
I know I can connect to the 5 analog inputs, which does detect the low voltage, but I have ~15 sensors. Is there a way to make these low voltage PIR sensors detectable on digital inputs 1 to 16? Without using a ton of dry contact relays haha
Thank you in advance!
