[arduino code examples for A16v3]-14 post data to mqtt topic
* MQTT example using W5500 and ESP32-S3
* Adapted from KinCony's W5500 TCP Server example
#include <SPI.h>
#include <Ethernet.h>
#include <PubSubClient.h>
// W5500 pin definitions
#define W5500_CS_PIN   15
#define W5500_RST_PIN  1
#define W5500_INT_PIN  2
#define W5500_CLK_PIN  42
#define W5500_MOSI_PIN 43
#define W5500_MISO_PIN 44
// MAC address (must be unique)
// Static IP settings
IPAddress ip(192, 168, 3, 55);
IPAddress gateway(192, 168, 3, 1);
IPAddress dns(192, 168, 3, 1);
// MQTT broker settings
const char* mqtt_server = "192.168.3.100";  // 可改为你的服务器
const int mqtt_port = 1883;
const char* mqtt_topic = "kincony/test";
// Ethernet and MQTT clients
EthernetClient ethClient;
PubSubClient mqttClient(ethClient);
// MQTT callback
void mqttCallback(char* topic, byte* payload, unsigned int length) {
  Serial.print("Message arrived [");
  Serial.print(topic);
  Serial.print("]: ");
  for (unsigned int i = 0; i < length; i++) {
    Serial.print((char)payload[i]);
  Serial.println();
void mqttReconnect() {
  while (!mqttClient.connected()) {
    Serial.print("Attempting MQTT connection...");
    if (mqttClient.connect("KinConyClient")) {
      Serial.println("connected");
      mqttClient.subscribe(mqtt_topic);  // 订阅主题
    } else {
      Serial.print("failed, rc=");
      Serial.print(mqttClient.state());
      Serial.println(" trying again in 5 seconds");
      delay(5000);
  // Reset W5500
  digitalWrite(W5500_RST_PIN, LOW);
  delay(100);
  digitalWrite(W5500_RST_PIN, HIGH);
  delay(100);
  // Start SPI
  Ethernet.init(W5500_CS_PIN);
  Serial.print("IP Address: ");
  mqttClient.setServer(mqtt_server, mqtt_port);
  mqttClient.setCallback(mqttCallback);
unsigned long lastMsg = 0;
  if (!mqttClient.connected()) {
    mqttReconnect();
  mqttClient.loop();
  // Publish message every 10 seconds
  unsigned long now = millis();
  if (now - lastMsg > 10000) {
    lastMsg = now;
    const char* msg = "Hello from KinCony ESP32S3 board + W5500";
    mqttClient.publish(mqtt_topic, msg);
    Serial.println("Published message");
arduino ino file download:
.zip   14-mqtt.zip (Size: 1.19 KB / Downloads: 675)
