06-23-2025, 05:39 AM
* This Arduino program reads 128 input channels from 8 PCF8575 modules on I2C Bus-2
* and controls 128 output channels on 8 PCF8575 modules on I2C Bus-1.
* When an input pin is pulled LOW (connected to GND), the corresponding output relay is turned ON (LOW).
* Otherwise, the relay is turned OFF (HIGH).
* I2C Bus-1 (Outputs):
* - SDA: GPIO 48
* - SCL: GPIO 47
* - Output1~16 : 0x27
* - Output17~32 : 0x26
* - Output33~48 : 0x23
* - Output49~64 : 0x22
* - Output65~80 : 0x25
* - Output81~96 : 0x24
* - Output97~112 : 0x21
* - Output113~128 : 0x20
* I2C Bus-2 (Inputs):
* - SDA: GPIO 12
* - SCL: GPIO 11
* - Input1~16 : 0x27
* - Input17~32 : 0x26
* - Input33~48 : 0x23
* - Input49~64 : 0x22
* - Input65~80 : 0x25
* - Input81~96 : 0x24
* - Input97~112 : 0x21
* - Input113~128 : 0x20
#include <Wire.h>
#include <PCF8575.h>
// Define two I2C buses for independent input/output communication
TwoWire I2C_Output = TwoWire(0); // Bus 1 - Outputs
TwoWire I2C_Input = TwoWire(1); // Bus 2 - Inputs
// === Output PCF8575 instances ===
PCF8575 output_1(0x27, &I2C_Output); // Output 1~16
PCF8575 output_2(0x26, &I2C_Output); // Output 17~32
PCF8575 output_3(0x23, &I2C_Output); // Output 33~48
PCF8575 output_4(0x22, &I2C_Output); // Output 49~64
PCF8575 output_5(0x25, &I2C_Output); // Output 65~80
PCF8575 output_6(0x24, &I2C_Output); // Output 81~96
PCF8575 output_7(0x21, &I2C_Output); // Output 97~112
PCF8575 output_8(0x20, &I2C_Output); // Output 113~128
// === Input PCF8575 instances ===
PCF8575 input_1(0x27, &I2C_Input); // Input 1~16
PCF8575 input_2(0x26, &I2C_Input); // Input 17~32
PCF8575 input_3(0x23, &I2C_Input); // Input 33~48
PCF8575 input_4(0x22, &I2C_Input); // Input 49~64
PCF8575 input_5(0x25, &I2C_Input); // Input 65~80
PCF8575 input_6(0x24, &I2C_Input); // Input 81~96
PCF8575 input_7(0x21, &I2C_Input); // Input 97~112
PCF8575 input_8(0x20, &I2C_Input); // Input 113~128
// === Create arrays for easy loop access ===
PCF8575* inputArray[8] = {
&input_1, &input_2, &input_3, &input_4,
&input_5, &input_6, &input_7, &input_8
PCF8575* outputArray[8] = {
&output_1, &output_2, &output_3, &output_4,
&output_5, &output_6, &output_7, &output_8
Serial.println("KinCony 128-Channel Input-Output Mapping Test");
// Initialize both I2C buses
I2C_Output.begin(48, 47); // SDA: GPIO48, SCL: GPIO47
I2C_Input.begin(12, 11); // SDA: GPIO12, SCL: GPIO11
// Initialize all PCF8575 chips and set initial output states
for (int i = 0; i < 8; i++) {
inputArray[i]->begin(); // Initialize input chip
outputArray[i]->begin(); // Initialize output chip
// Set all output pins HIGH (relay OFF)
for (int j = 0; j < 16; j++) {
outputArray[i]->write(j, HIGH);
for (int chip = 0; chip < 8; chip++) {
for (int pin = 0; pin < 16; pin++) {
bool inputState = inputArray[chip]->read(pin);
// If input is LOW (button pressed or contact closed), turn ON relay (set output LOW)
// Otherwise, turn OFF relay (set output HIGH)
outputArray[chip]->write(pin, inputState ? HIGH : LOW);
delay(200); // Delay to prevent I2C bus flooding
6-input-trigger-output.zip (Size: 1.33 KB / Downloads: 281)
6-input-trigger-output.ino.merged.zip (Size: 192.36 KB / Downloads: 267)
