KC868-A8V3 and ESPHome firmware
I want to load the config yaml provided by you with a DS18b20:
I get this error message: Huh
.txt   A8v3-HA.txt (Size: 8.41 KB / Downloads: 263)
do you want to use tuya app? if you don't want use it. you can disable it.
(08-25-2025, 10:39 AM)admin Wrote: do you want to use tuya app? if you don't want use it. you can disable it.
No, Tuya app. APP, how and where can it be deactivated?
after reinstalling the original "config yaml file for ESPHome" -> https://www.kincony.com/forum/showthread.php?tid=7971 I get the following error!
When I try to view the LOGS, I get another error message!
tested with 3pcs of DS18B20 for KC868-A8v3 using ESPHome.
S4:GPIO14
S3:GPIO48
S2:GPIO13
S1:GPIO40
[Image: attachment.php?aid=8217]
[Image: attachment.php?aid=8218]
esphome yaml file:
.txt   A8v3-DS18B20-ESPHome-yaml.txt (Size: 8.48 KB / Downloads: 265)
esphome key point:
  - platform: dallas_temp
    one_wire_id: bus_S4
    name: "S4 Temperature"
    update_interval: 10s
    one_wire_id: bus_S3
    name: "S3 Temperature"
    one_wire_id: bus_S2
    name: "S2 Temperature"
one_wire:
    pin: GPIO14
    pin: GPIO48
    pin: GPIO13
