N10 configure yaml for ESPhome
  friendly_name: n10
  board: esp32-s3-devkitc-1
    type: arduino
  # baud_rate: 0
ota:
  platform: esphome
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO41
  interrupt_pin: GPIO2
  reset_pin: GPIO1
uart:
  rx_pin: 9
  tx_pin: 10
  baud_rate: 115200
  stop_bits: 1
  data_bits: 8
  parity: NONE
web_server:
  port: 80
text_sensor:
  - platform: ethernet_info
    ip_address:
      name: ESP IP Address
      address_0:
        name: ESP IP Address 0
      address_1:
        name: ESP IP Address 1
      address_2:
        name: ESP IP Address 2
      address_3:
        name: ESP IP Address 3
      address_4:
        name: ESP IP Address 4
    dns_address:
      name: ESP DNS Address
    mac_address:
      name: ESP MAC Address
font:
  - file: "gfonts://Roboto"
  sda: 18
  scl: 17
display:
  - platform: ssd1306_i2c
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 15, id(roboto), "IP: %s", id(eth_ip).state.c_str());
modbus:
modbus_controller:
  - address: 1
    update_interval: 5s
  - platform: modbus_controller
    address: 100
    register_type: holding
    unit_of_measurement: A
    device_class: current
    accuracy_decimals: 3
    value_type: U_DWORD_R
    filters:
      - multiply: 0.001
    address: 102
    filters:
      - multiply: 0.001
    address: 104
    filters:
      - multiply: 0.001
    address: 106
    filters:
      - multiply: 0.001
    address: 108
    filters:
      - multiply: 0.001
    address: 110
    filters:
      - multiply: 0.001
    address: 112
    filters:
      - multiply: 0.001
    address: 114
    filters:
      - multiply: 0.001
    address: 116
    filters:
      - multiply: 0.001
    address: 118
    filters:
      - multiply: 0.001
    address: 120
    unit_of_measurement: W
    device_class: power
    accuracy_decimals: 1
    filters:
      - multiply: 0.1
    address: 122
    device_class: power
    filters:
      - multiply: 0.1
    address: 124
    device_class: power
    filters:
      - multiply: 0.1
    address: 126
    device_class: power
    filters:
      - multiply: 0.1
    address: 128
    device_class: power
    filters:
      - multiply: 0.1
    address: 130
    device_class: power
    filters:
      - multiply: 0.1
    address: 132
    device_class: power
    filters:
      - multiply: 0.1
    address: 134
    device_class: power
    filters:
      - multiply: 0.1
    address: 136
    device_class: power
    filters:
      - multiply: 0.1
    address: 138
    device_class: power
    filters:
      - multiply: 0.1
    state_class: total_increasing
    device_class: energy
    address: 140
    unit_of_measurement: kWh
    address: 142
    address: 144
    address: 146
    address: 148
    address: 150
    address: 152
    address: 154
    address: 156
    address: 158
    address: 160
    address: 162
    unit_of_measurement: V
    device_class: voltage
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 163
    unit_of_measurement: Hz
    device_class: frequency
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 164
    unit_of_measurement: °C
    device_class: temperature
    value_type: FP32_R
yaml download:
.txt   N10-HA.txt (Size: 10.03 KB / Downloads: 113)
