11-03-2025, 11:39 PM
friendly_name: f4
platformio_options:
board_build.extra_flags:
# WIFI_CONTROL_SELF_MODE = 0
# WIFI_CONTROL_SELF_MODE = 1
board: esp32-s3-devkitc-1
type: arduino
external_components:
- source:
type: git
ref: v1.3.0
encryption:
type: W5500
clk_pin: GPIO42
mosi_pin: GPIO43
miso_pin: GPIO44
cs_pin: GPIO41
interrupt_pin: GPIO2
reset_pin: GPIO1
- id: bus_a
sda: 8
scl: 18
frequency: 400kHz
- id: 'pcf8574_hub_in_1' # for DI1-DI4 Relay1-Relay4
i2c_id: bus_a
address: 0x24
uart:
- id: uart_1 #RS485
baud_rate: 9600
debug:
direction: BOTH
dummy_receiver: true
after:
timeout: 10ms
tx_pin: 16
rx_pin: 17
- id: tuya_mcu_uart
tx_pin: GPIO39
rx_pin: GPIO38
baud_rate: 9600
tuya_wifi_mcu:
# tuya mcu product id
product_id: nnr2qbxrwuleqqgc
uart_id: tuya_mcu_uart
wifi_reset_pin: 28
wifi_led_pin: 16
- platform: uart
uart_id: uart_1
pcf8574: pcf8574_hub_in_1
number: 4
mode: OUTPUT
- platform: tuya_wifi_mcu
dp_id: 1
# hide from homeassistant ui
internal: true
bind_switch_id: "f4_output01"
number: 5
mode: OUTPUT
dp_id: 2
internal: true
bind_switch_id: "f4_output02"
number: 6
mode: OUTPUT
dp_id: 3
internal: true
bind_switch_id: "f4_output03"
number: 7
mode: OUTPUT
dp_id: 4
internal: true
bind_switch_id: "f4_output04"
dp_id: 111
bind_binary_sensor_id: f4_input01
internal: true
dp_id: 112
bind_binary_sensor_id: f4_input02
internal: true
dp_id: 113
bind_binary_sensor_id: f4_input03
internal: true
dp_id: 114
bind_binary_sensor_id: f4_input04
internal: true
##pull-up resistance on PCB
number: 48
number: 47
number: 21
number: 15
## without resistance on PCB
number: 14
inverted: false
number: 40
inverted: false
inverted: false
- platform: adc
pin: 5
name: "f4 A1 Voltage"
update_interval: 5s
attenuation: 11db
filters:
- lambda:
if (x >= 3.11) {
return x * 1.60256;
} else if (x <= 0.15) {
return 0;
} else {
return x * 1.51;
- platform: adc
pin: 7
name: "f4 A2 Voltage"
update_interval: 5s
attenuation: 11db
filters:
# - multiply: 1.51515
- lambda:
if (x >= 3.11) {
return x * 1.60256;
return 0;
} else {
return x * 1.51;
- platform: adc
pin: 6
name: "f4 A3 Current"
update_interval: 5s
unit_of_measurement: mA
attenuation: 11db
filters:
- multiply: 6.66666666
- platform: adc
pin: 4
name: "f4 A4 Current"
update_interval: 5s
attenuation: 11db
filters:
web_server:
port: 80
font:
- file: "gfonts://Roboto"
display:
- platform: ssd1306_i2c
i2c_id: bus_a
model: "SSD1306 128x64"
address: 0x3C
lambda: |-
it.printf(0, 0, id(roboto), "KinCony f4");
F4-HA-tuya.txt (Size: 6.04 KB / Downloads: 182)
