01-11-2026, 05:34 PM
The esp32 is rebooting all the time because he doesn't find the lan connection.
flash Kincony software to KC868-AP
01-12-2026, 01:17 AM
i have tested with KCS_KC868_AP_V2.2.18.bin file, after downloaded, re power on of board, will show the AP wifi signal.
01-12-2026, 12:00 PM
(This post was last modified: 01-12-2026, 05:21 PM by guycaluwaerts.)
yes, but on the picture the ethernet lan is connected. Problem seems when ethernet cable is not connected
01-12-2026, 12:11 PM
tomorrow we will test without ethernet.
01-13-2026, 12:14 AM
i have tested, no ethernet cable, i power on AP board. then will see the wifi AP signal.
if you can't work, take a video how you download firmware, send to whatsapp number: +86-15381188302
01-13-2026, 07:27 PM
01-14-2026, 12:23 AM
if your board can't work, tell me your order number, we re send you a new one.
01-15-2026, 04:58 PM
It's not normal that the esp32 stop to work when he cannot find the ethernet connection. He still can work over wifi.
Is it possible to change the software so that the esp32 only give a message that the lan connection is not working but he works further over wifi ?
01-15-2026, 11:24 PM
ethernet and wifi will work at the same time, if using KCS firmware. you can give me your order number, we can re send you a new KC868-AP pcb.
| 1 Guest(s) |
