Threads: 1
05-03-2023, 09:19 PM
(This post was last modified: 05-04-2023, 02:35 AM by Horlagold .)
Please help me choose and recommend devices for my home automations
Six water leak sensor
Two Humidity sensor
Two temperature sensor
A device that can control
three way or four way light switch
One doorbell chime
One energy meter
Threads: 1,547
which software you want to use? home assistant or tuya app?
Threads: 1,547
you can chose KC868-Server (install home assitant) + KC868-A series board according to your load channel.
Threads: 1
Okay. How will I wire a 3 way light switch to connect to the KC868 A8 board
Threads: 1,547
connect to KC868-A8's digital input ports.
Threads: 1
Thanks. I want to control of a three or four way light switch with a relay switch controlled by KC868-A8s. Do you have a product such as item “D” in my diagram a “smart relay switch”or recommend a wiring solution to control a digital smart relay switch. I have attached the diagram below.
Image(s)
Threads: 1,547
sorry, i don't understand you , what you want to do?
Threads: 1
How do I add KinCony products to control a 3 way light switch
Threads: 1,547
do you want use 3 switch buttons control one relay (lamp)?
