07-26-2021, 12:44 AM
improvement:
1. Support connect to 2 cloud server work at the same time by UDP (KinCony's Cloud server) and MQTT (private MQTT broker server)
2. Fixed controller have delay time when send a large number of commands control relay in TCP Server mode.
3. Add wifi and ethernet reset command by RS232 for manufactory. send command set ethernet and wifi module work as "DHCP" and "UDP" mode. (This not for end user)
KC868-H32B V4.32 firmware download: firmware only for KC868-H32B
Relay32_V432_210725.zip (Size: 44.92 KB / Downloads: 750)
download the ZIP file , unzip update the bin file for KC868-H32B relay controller by USB-RS232 cable.
firmware update tool download: https://www.kincony.com/download/KC868-C...loader.zip
