KinCony ATF (ESP32 SD card module) ESPHome yaml for home assistant
download yaml:
.txt   ATF-HA.txt (Size: 2.08 KB / Downloads: 384)
  friendly_name: atf
    type: arduino
  encryption:
    key: "w7SHSfiO/jo57FMsWHzLoexB93cf1YmRH7YUVvJuVQ4="
ota:
  password: "122b54ecaa3db2cc9455e008d112a4b6"
wifi:
  ssid: "KinCony"
  password: "a12345678"
  ap:
    ssid: "Atf Fallback Hotspot"
    password: "dPQX1XykXHPe"
captive_portal:
      number: 21
      number: 22
      number: 14
      number: 27
      number: 13
      number: 15
      number: 16
      number: 4
      number: 36
      number: 37
      number: 38
      number: 39
      number: 34
      number: 35
      number: 26
      number: 25
      number: 32
      number: 33
web_server:
  port: 80
