A32 Pro ESPHome yaml for home assistant
  friendly_name: a32-Pro
  platformio_options:
    board_build.flash_mode: dio
  board: esp32-s3-devkitc-1
    type: esp-idf
# ota:
#   password: "5f17bccba50c65f60200db69f1b1ebbe"
# wifi:
#   ssid: KinCony
#   password: a12345678
#   # Enable fallback hotspot (captive portal) in case wifi connection fails
#   ap:
#     ssid: "A32-Pro Fallback Hotspot"
#     password: "25JYfblp8QJP"
# captive_portal:
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO44
  miso_pin: GPIO40
  cs_pin: GPIO39
  interrupt_pin: GPIO41
  reset_pin: GPIO43
   - id: bus_a
     sda: 11
     scl: 10
     frequency: 400kHz
xl9535:
  - id: xl9535_hub_out1 # for output channel 1-16
    address: 0x21
  - id: xl9535_hub_out2 # for output channel 17-32
    address: 0x22
  - id: xl9535_hub_in1 # for input channel 1-16
    address: 0x24
  - id: xl9535_hub_in2 # for input channel 17-32
    address: 0x25
  - id: 'pcf8574_in_3'  # for input channel 33-40
    address: 0x23
uart:
  - id: uart_1
    baud_rate: 9600
    debug:
      direction: BOTH
      dummy_receiver: true
      after:
        timeout: 10ms
    tx_pin: 9
    rx_pin: 8
  - id: uart_tuya
    baud_rate: 115200
    debug:
      direction: BOTH
      after:
        timeout: 10ms
    tx_pin: 15
    rx_pin: 16
  - id: uart_sim7600
    baud_rate: 115200
    debug:
      direction: BOTH
      after:
        timeout: 10ms
      sequence:
    tx_pin: 18
    rx_pin: 17
    pin: 45
  - platform: uart
    uart_id: uart_1
  - platform: uart
    uart_id: uart_sim7600
    data: "AT+CGSN\r\n" # read 4G SIM7600 ID
  # - platform: uart
  #   uart_id: uart_tuya
  #   name: "UART TUYA2"
  #   data: [0x55, 0xaa, 0x03, 0x00, 0x00, 0x01, 0x01, 0x04]
    name: A32 Pro Switch01
      xl9535: xl9535_hub_out1
      mode: OUTPUT
    name: A32 Pro Switch02
      mode: OUTPUT
    name: A32 Pro Switch03
      mode: OUTPUT
    name: A32 Pro Switch04
      mode: OUTPUT
    name: A32 Pro Switch05
      number: 4
      mode: OUTPUT
    name: A32 Pro Switch06
      number: 5
      mode: OUTPUT
    name: A32 Pro Switch07
      number: 6
      mode: OUTPUT
    name: A32 Pro Switch08
      number: 7
      mode: OUTPUT
    name: A32 Pro Switch09
      number: 10
      mode: OUTPUT
    name: A32 Pro Switch10
      number: 11
      mode: OUTPUT
    name: A32 Pro Switch11
      number: 12
      mode: OUTPUT
    name: A32 Pro Switch12
      number: 13
      mode: OUTPUT
    name: A32 Pro Switch13
      number: 14
      mode: OUTPUT
    name: A32 Pro Switch14
      number: 15
      mode: OUTPUT
    name: A32 Pro Switch15
      number: 16
      mode: OUTPUT
    name: A32 Pro Switch16
      number: 17
      mode: OUTPUT
    name: A32 Pro Switch17
      xl9535: xl9535_hub_out2
      mode: OUTPUT
    name: A32 Pro Switch18
      mode: OUTPUT
    name: A32 Pro Switch19
      mode: OUTPUT
    name: A32 Pro Switch20
      mode: OUTPUT
    name: A32 Pro Switch21
      number: 4
      mode: OUTPUT
    name: A32 Pro Switch22
      number: 5
      mode: OUTPUT
    name: A32 Pro Switch23
      number: 6
      mode: OUTPUT
    name: A32 Pro Switch24
      number: 7
      mode: OUTPUT
    name: A32 Pro Switch25
      number: 10
      mode: OUTPUT
    name: A32 Pro Switch26
      number: 11
      mode: OUTPUT
    name: A32 Pro Switch27
      number: 12
      mode: OUTPUT
    name: A32 Pro Switch28
      number: 13
      mode: OUTPUT
    name: A32 Pro Switch29
      number: 14
      mode: OUTPUT
    name: A32 Pro Switch30
      number: 15
      mode: OUTPUT
    name: A32 Pro Switch31
      number: 16
      mode: OUTPUT
    name: A32 Pro Switch32
      number: 17
      mode: OUTPUT
    name: A32 Pro DI01
      xl9535: xl9535_hub_in1
    name: A32 Pro DI02
    name: A32 Pro DI03
    name: A32 Pro DI04
    name: A32 Pro DI05
      number: 4
    name: A32 Pro DI06
      number: 5
    name: A32 Pro DI07
      number: 6
    name: A32 Pro DI08
      number: 7
    name: A32 Pro DI09
      number: 10
    name: A32 Pro DI10
      number: 11
    name: A32 Pro DI11
      number: 12
    name: A32 Pro DI12
      number: 13
    name: A32 Pro DI13
      number: 14
    name: A32 Pro DI14
      number: 15
    name: A32 Pro DI15
      number: 16
    name: A32 Pro DI16
      number: 17
    name: "A32 Pro TMP1"
    name: "A32 Pro TMP2"
    name: "A32 Pro DL"
    name: "A32 Pro DTUYA"
      number: 21
    name: A32 Pro DI17
      xl9535: xl9535_hub_in2
    name: A32 Pro DI18
    name: A32 Pro DI19
    name: A32 Pro DI20
    name: A32 Pro DI21
      number: 4
    name: A32 Pro DI22
      number: 5
    name: A32 Pro DI23
      number: 6
    name: A32 Pro DI24
      number: 7
    name: A32 Pro DI25
      number: 10
    name: A32 Pro DI26
      number: 11
    name: A32 Pro DI27
      number: 12
    name: A32 Pro DI28
      number: 13
    name: A32 Pro DI29
      number: 14
    name: A32 Pro DI30
      number: 15
    name: A32 Pro DI31
      number: 16
    name: A32 Pro DI32
      number: 17
    name: A32 Pro DI33
      pcf8574: pcf8574_in_3
    name: A32 Pro DI34
    name: A32 Pro DI35
    name: A32 Pro DI36
    name: A32 Pro DI37
      number: 4
    name: A32 Pro DI38
      number: 5
    name: A32 Pro DI39
      number: 6
    name: A32 Pro DI40
      number: 7
gp8403:
  voltage: 10V
output:
  - platform: gp8403
    gp8403_id: my_gp8403
    channel: 0
  - platform: gp8403
    channel: 1
light:
  - platform: monochromatic
    name: "A32 Pro-DAC-0"
    output: gp8403_output_1
    name: "A32 Pro-DAC-1"
    output: gp8403_output_2
  - platform: adc
    pin: 7
    name: "A32 Pro A1 Voltage"
    update_interval: 5s
    attenuation: 11db
    filters:
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
          } else if (x <= 0.15) {
            return 0;
          } else {
            return x * 1.51;
  - platform: adc
    pin: 6
    name: "A32 Pro A2 Voltage"
    update_interval: 5s
    attenuation: 11db
    filters:
      # - multiply: 1.51515
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
            return 0;
          } else {
            return x * 1.51;
  - platform: adc
    pin: 5
    name: "A32 Pro A3 Current"
    update_interval: 5s
    unit_of_measurement: mA
    attenuation: 11db
    filters:
      - multiply: 6.66666666
  - platform: adc
    pin: 4
    name: "A32 Pro A4 Current"
    update_interval: 5s
    attenuation: 11db
    filters:
web_server:
  port: 80
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    i2c_id: bus_a
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(roboto), "A32 Pro");
download yaml:
.txt   A32_Pro-ESPHome.txt (Size: 14.46 KB / Downloads: 173)
