PCF8574 IO Expansion i2c digital input board -DI8 ESPHome config yaml demo
  sda: 4    #replace by your board's pin define
  scl: 5     #replace by your board's pin define
    address: 0x22    #replace by your PCF8574 address
      pcf8574: pcf8574_hub_in_1
      number: 4
      number: 5
      number: 6
      number: 7
download yaml demo for ESPHome:
.txt   DI8_config_yaml.txt (Size: 1.53 KB / Downloads: 416)
about A0,A1,A2 i2c address setting:
A0  A1  A2
0    0    0    =0x20
0    0    1    =0x21
0    1    0    =0x22
0    1    1    =0x23
1    0    0    =0x24
1    0    1    =0x25
1    1    0    =0x26
1    1    1    =0x27
Hello.
Is it possible to control the relays of the expansion i2c board by mqtt?
I have an A16 with firmware 2.2.13
Thanks
that need you config by esphome or write your own arduino code for esp32.
