kc868_A8: NodeMCU-32s, 80Mhz, 115200. None. Disabled sur COM4.
Hi
please help, i didnt connect the KC868-A8 bord with arduino app.
When read information from board i receive the picture attached
this is a arudino ADC simple demo source for KC868-A8.
you can open it ,directly to compile and download, test whether work well.
.zip   ADC_INOUT.zip (Size: 842 bytes / Downloads: 700)
(07-13-2024, 01:38 AM)admin Wrote: this is a arudino ADC simple demo source for KC868-A8.
Hi; the problem is connection between comuputer and KC868-A8 (disabled on com4) but it's working with arduino uno.
do you have installed USB driver, here is link: https://www.kincony.com/download/CH341SER.zip
(07-14-2024, 12:31 AM)admin Wrote: do you have installed USB driver, here is link: https://www.kincony.com/download/CH341SER.zip
Yes, usb driver installed and port selected in arduino app.
yes usb driver installed
whether can download firmware?
(07-14-2024, 12:33 PM)admin Wrote: whether can download firmware?
hi, You mean by that the flash firmware. yes i finished all prog for the product. Tuya smart is working well locally and remotely
I want to start programming with arduino app but the is a fail of connection.
Port driver is installed. I think that the arduino app  didn't know the panel as NodeMCU 32s.
if you can download firmware to A8 board, that means PCB hardware is OK.
you can try to use another computer have a test.
(07-15-2024, 12:36 AM)admin Wrote: if you can download firmware to A8 board, that means PCB hardware is OK.
Hi, now it’s working when I re installed the arduino app. Thanks for your support.
As I’m  a starter as programmer with arduino’s app, please tell me the inquired steps to follow, I want to put a program in kc868A8 and kc868A16 to manage input and output ans to have Xbox or tuya also.
FYI: I have a code tuya and it’s working well.
i suggest you download KCS firmware , then you can use KBOX phone app and Tuya app. it's easy, without any code. Not need to use arduino write code.
here is KCS firmware online guide: https://www.kincony.com/esp32-kcsv2-firmware.html
