I received a new A8 board, downloaded KCS with success, off/on the board. But I cant see the board on my net. Even with your tool udp scan. The board is on the same switch than my PC.
Udp scan can see my two other kincony board. I tried both kcs V2, the V1..no luck.
No problem with Tasmota, I have a wifi access to the board (but not via wire).
I remember , installing them last year was not esay for me, spending too much time.
I have 110 ish IP address on my Lan, many vendors, so far switches from shelly ,dingtian.
I added kincony for the 1wire support. But man, am I stupid for having so much problem with the K boards boards or is my english broken? I hope so and that you will point me to the solution.
Would be so easy for me, to have new board coming with kcs de facto.
Also, I tried to integarte it on HA. I thought it would be easy like the videos show : just copy and paste! . No way, I am fighting with the yaml syntax . I know I should learn the yaml syntax. But you could simplify my job by posting yaml files not text ( or it is hidden on the website?) . Yes I am dumb with yaml. But for newbies like me, we would be more enclined to buy kincony stuff.
Question:
When kcs starts for the first time, is dhcp activated? on wired lan first , right?
I posted my request by email, as you suggest when I contacted via ali. You reply that I should go to the forum. So please for new buyers, on ali , suggest to contact you on the forum.
Thanks
Question:
Thanks
