A32 Pro ESPHome yaml for home assistant and Tuya app work simultaneously without MQTT
  friendly_name: a32-Pro-arduino
  platformio_options:
    board_build.extra_flags:
      # WIFI_CONTROL_SELF_MODE = 0
      # WIFI_CONTROL_SELF_MODE = 1
      - "-DWIFI_CONTROL_SELF_MODE=0"
external_components:
  - source:
      type: git
      ref: v1.3.1
  board: esp32-s3-devkitc-1
    type: arduino
# logger:
  encryption:
    key: "fBpihEYPVlfKaE4ZIcY0uRcJ134u7DBKzzskk994+Lw="
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO44
  miso_pin: GPIO40
  cs_pin: GPIO39
  interrupt_pin: GPIO41
  reset_pin: GPIO43
uart:
  tx_pin: 15
  rx_pin: 16
  baud_rate: 9600
tuya_wifi_mcu:
  # tuya mcu product id
  product_id: fwy7fk4mzay3kern
  uart_id: tuya_mcu_uart
  wifi_reset_pin: 21
  wifi_led_pin: 45
   - id: bus_a
     sda: 11
     scl: 10
     frequency: 400kHz
xl9535:
  - id: xl9535_hub_out1 # for output channel 1-16
    address: 0x21
  - id: xl9535_hub_out2 # for output channel 17-32
    address: 0x22
  - id: xl9535_hub_in1 # for input channel 1-16
    address: 0x24
  - id: xl9535_hub_in2 # for input channel 17-32
    address: 0x25
  - id: 'pcf8574_in_3'  # for input channel 33-40
    address: 0x23
    pin: 45
    name: A32 Pro Switch01
      xl9535: xl9535_hub_out1
      mode: OUTPUT
  - platform: tuya_wifi_mcu
    name: A32 Pro Switch01 Tuya
    dp_id: 101
    # hide from homeassistant ui
    internal: true
    bind_switch_id: "a32_pro_switch01"
    name: A32 Pro Switch02
      mode: OUTPUT
    name: A32 Pro Switch02 Tuya
    dp_id: 102
    internal: true
    bind_switch_id: "a32_pro_switch02"
    name: A32 Pro Switch03
      mode: OUTPUT
    name: A32 Pro Switch03 Tuya
    dp_id: 103
    internal: true
    bind_switch_id: "a32_pro_switch03"
    name: A32 Pro Switch04
      mode: OUTPUT
    name: A32 Pro Switch04 Tuya
    dp_id: 104
    internal: true
    bind_switch_id: "a32_pro_switch04"
    name: A32 Pro Switch05
      number: 4
      mode: OUTPUT
    name: A32 Pro Switch05 Tuya
    dp_id: 105
    internal: true
    bind_switch_id: "a32_pro_switch05"
    name: A32 Pro Switch06
      number: 5
      mode: OUTPUT
    name: A32 Pro Switch06 Tuya
    dp_id: 106
    internal: true
    bind_switch_id: "a32_pro_switch06"
    name: A32 Pro Switch07
      number: 6
      mode: OUTPUT
    name: A32 Pro Switch07 Tuya
    dp_id: 107
    internal: true
    bind_switch_id: "a32_pro_switch07"
    name: A32 Pro Switch08
      number: 7
      mode: OUTPUT
    name: A32 Pro Switch08 Tuya
    dp_id: 108
    internal: true
    bind_switch_id: "a32_pro_switch08"
    name: A32 Pro Switch09
      number: 10
      mode: OUTPUT
    name: A32 Pro Switch09 Tuya
    dp_id: 109
    internal: true
    bind_switch_id: "a32_pro_switch09"
    name: A32 Pro Switch10
      number: 11
      mode: OUTPUT
    name: A32 Pro Switch10 Tuya
    dp_id: 110
    internal: true
    bind_switch_id: "a32_pro_switch10"
    name: A32 Pro Switch11
      number: 12
      mode: OUTPUT
    name: A32 Pro Switch11 Tuya
    dp_id: 111
    internal: true
    bind_switch_id: "a32_pro_switch11"
    name: A32 Pro Switch12
      number: 13
      mode: OUTPUT
    name: A32 Pro Switch12 Tuya
    dp_id: 112
    internal: true
    bind_switch_id: "a32_pro_switch12"
    name: A32 Pro Switch13
      number: 14
      mode: OUTPUT
    name: A32 Pro Switch13 Tuya
    dp_id: 113
    internal: true
    bind_switch_id: "a32_pro_switch13"
    name: A32 Pro Switch14
      number: 15
      mode: OUTPUT
    name: A32 Pro Switch14 Tuya
    dp_id: 114
    internal: true
    bind_switch_id: "a32_pro_switch14"
    name: A32 Pro Switch15
      number: 16
      mode: OUTPUT
    name: A32 Pro Switch15 Tuya
    dp_id: 115
    internal: true
    bind_switch_id: "a32_pro_switch15"
    name: A32 Pro Switch16
      number: 17
      mode: OUTPUT
    name: A32 Pro Switch16 Tuya
    dp_id: 116
    internal: true
    bind_switch_id: "a32_pro_switch16"
    name: A32 Pro Switch17
      xl9535: xl9535_hub_out2
      mode: OUTPUT
    name: A32 Pro Switch17 Tuya
    dp_id: 117
    internal: true
    bind_switch_id: "a32_pro_switch17"
    name: A32 Pro Switch18
      mode: OUTPUT
    name: A32 Pro Switch18 Tuya
    dp_id: 118
    internal: true
    bind_switch_id: "a32_pro_switch18"
    name: A32 Pro Switch19
      mode: OUTPUT
    name: A32 Pro Switch19 Tuya
    dp_id: 119
    internal: true
    bind_switch_id: "a32_pro_switch19"
    name: A32 Pro Switch20
      mode: OUTPUT
    name: A32 Pro Switch20 Tuya
    dp_id: 120
    internal: true
    bind_switch_id: "a32_pro_switch20"
    name: A32 Pro Switch21
      number: 4
      mode: OUTPUT
    name: A32 Pro Switch21 Tuya
    dp_id: 121
    internal: true
    bind_switch_id: "a32_pro_switch21"
    name: A32 Pro Switch22
      number: 5
      mode: OUTPUT
    name: A32 Pro Switch22 Tuya
    dp_id: 122
    internal: true
    bind_switch_id: "a32_pro_switch22"
    name: A32 Pro Switch23
      number: 6
      mode: OUTPUT
    name: A32 Pro Switch23 Tuya
    dp_id: 123
    internal: true
    bind_switch_id: "a32_pro_switch23"
    name: A32 Pro Switch24
      number: 7
      mode: OUTPUT
    name: A32 Pro Switch24 Tuya
    dp_id: 124
    internal: true
    bind_switch_id: "a32_pro_switch24"
    name: A32 Pro Switch25
      number: 10
      mode: OUTPUT
    name: A32 Pro Switch25 Tuya
    dp_id: 125
    internal: true
    bind_switch_id: "a32_pro_switch25"
    name: A32 Pro Switch26
      number: 11
      mode: OUTPUT
    name: A32 Pro Switch26 Tuya
    dp_id: 126
    internal: true
    bind_switch_id: "a32_pro_switch26"
    name: A32 Pro Switch27
      number: 12
      mode: OUTPUT
    name: A32 Pro Switch27 Tuya
    dp_id: 127
    internal: true
    bind_switch_id: "a32_pro_switch27"
    name: A32 Pro Switch28
      number: 13
      mode: OUTPUT
    name: A32 Pro Switch28 Tuya
    dp_id: 128
    internal: true
    bind_switch_id: "a32_pro_switch28"
    name: A32 Pro Switch29
      number: 14
      mode: OUTPUT
    name: A32 Pro Switch29 Tuya
    dp_id: 129
    internal: true
    bind_switch_id: "a32_pro_switch29"
    name: A32 Pro Switch30
      number: 15
      mode: OUTPUT
    name: A32 Pro Switch30 Tuya
    dp_id: 130
    internal: true
    bind_switch_id: "a32_pro_switch30"
    name: A32 Pro Switch31
      number: 16
      mode: OUTPUT
    name: A32 Pro Switch31 Tuya
    dp_id: 131
    internal: true
    bind_switch_id: "a32_pro_switch31"
    name: A32 Pro Switch32
      number: 17
      mode: OUTPUT
    name: A32 Pro Switch32 Tuya
    dp_id: 132
    internal: true
    bind_switch_id: "a32_pro_switch32"
    name: A32 Pro DI01
      xl9535: xl9535_hub_in1
    name: A32 Pro DI01 Tuya
    dp_id: 133
    bind_binary_sensor_id: a32_pro_di01
    internal: true
    name: A32 Pro DI02
    name: A32 Pro DI02 Tuya
    dp_id: 134
    bind_binary_sensor_id: a32_pro_di02
    internal: true
    name: A32 Pro DI03
    name: A32 Pro DI03 Tuya
    dp_id: 135
    bind_binary_sensor_id: a32_pro_di03
    internal: true
    name: A32 Pro DI04
    name: A32 Pro DI04 Tuya
    dp_id: 136
    bind_binary_sensor_id: a32_pro_di04
    internal: true
    name: A32 Pro DI05
      number: 4
    name: A32 Pro DI06
      number: 5
    name: A32 Pro DI07
      number: 6
    name: A32 Pro DI08
      number: 7
    name: A32 Pro DI09
      number: 10
    name: A32 Pro DI10
      number: 11
    name: A32 Pro DI11
      number: 12
    name: A32 Pro DI12
      number: 13
    name: A32 Pro DI13
      number: 14
    name: A32 Pro DI14
      number: 15
    name: A32 Pro DI15
      number: 16
    name: A32 Pro DI16
      number: 17
    name: "A32 Pro TMP1"
    name: "A32 Pro TMP2"
    name: "A32 Pro DL"
    name: "A32 Pro DTUYA"
      number: 21
    name: A32 Pro DI17
      xl9535: xl9535_hub_in2
    name: A32 Pro DI18
    name: A32 Pro DI19
    name: A32 Pro DI20
    name: A32 Pro DI21
      number: 4
    name: A32 Pro DI22
      number: 5
    name: A32 Pro DI23
      number: 6
    name: A32 Pro DI24
      number: 7
    name: A32 Pro DI25
      number: 10
    name: A32 Pro DI26
      number: 11
    name: A32 Pro DI27
      number: 12
    name: A32 Pro DI28
      number: 13
    name: A32 Pro DI29
      number: 14
    name: A32 Pro DI30
      number: 15
    name: A32 Pro DI31
      number: 16
    name: A32 Pro DI32
      number: 17
    name: A32 Pro DI33
      pcf8574: pcf8574_in_3
    name: A32 Pro DI34
    name: A32 Pro DI35
    name: A32 Pro DI36
    name: A32 Pro DI37
      number: 4
    name: A32 Pro DI38
      number: 5
    name: A32 Pro DI39
      number: 6
    name: A32 Pro DI40
      number: 7
gp8403:
  voltage: 10V
output:
  - platform: gp8403
    gp8403_id: my_gp8403
    channel: 0
  - platform: gp8403
    channel: 1
light:
  - platform: monochromatic
    name: "A32 Pro-DAC-0"
    output: gp8403_output_1
    name: "A32 Pro-DAC-1"
    output: gp8403_output_2
  - platform: adc
    pin: 7
    name: "A32 Pro A1 Voltage"
    update_interval: 5s
    attenuation: 11db
    filters:
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
          } else if (x <= 0.15) {
            return 0;
          } else {
            return x * 1.51;
  - platform: adc
    pin: 6
    name: "A32 Pro A2 Voltage"
    update_interval: 5s
    attenuation: 11db
    filters:
      # - multiply: 1.51515
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
            return 0;
          } else {
            return x * 1.51;
  - platform: adc
    pin: 5
    name: "A32 Pro A3 Current"
    update_interval: 5s
    unit_of_measurement: mA
    attenuation: 11db
    filters:
      - multiply: 6.66666666
  - platform: adc
    pin: 4
    name: "A32 Pro A4 Current"
    update_interval: 5s
    attenuation: 11db
    filters:
web_server:
  port: 80
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    i2c_id: bus_a
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(roboto), "A32 Pro");
.txt   A32_Pro-ESPHome_arduino_type.txt (Size: 21.88 KB / Downloads: 654)
- source:
type: git
ref: v1.1.0
with new code version:
- source:
type: git
ref: v1.3.1
