M16v2 and SCT013-050
Dear Sir,
I have bought a M16v2 recently and try to make it work with SCT013-050 50A/1V sensors (https://www.aliexpress.com/item/10050092...1802lqJyc9) with the jumper positioned in the "V" measurement on the board.
I've used the last yaml code you provided (also attached) however it is not measuring anything.
My house has 3 phases and I have already checked all 3 phases as they are coming from teh grid as well as from a socket.
I've never received any measurement the Amperage is always 0A and the RAW measurements 0.11A, 0.12A, 0.13A
Any idea what is going on?
Tks a lot
.txt   Kincony-m16-v2.txt (Size: 9.86 KB / Downloads: 10)
please confirm with the CT seller, whether is 2000:1
(06-10-2026, 12:44 PM)admin Wrote: please confirm with the CT seller, whether is 2000:1
Hello again,
It is 1800:1
you should chose 2000:1 CT sensor, suggest you buy CT sensor from KinCony online shop.
