[arduino code examples for MT4]-05 RS485 communication test
* RS485 Communication Test
* The TXD pin is defined as GPIO 16 and RXD pin is defined as GPIO 17.
#include <HardwareSerial.h>
// Define RS485 pins
#define RS485_RXD 7
#define RS485_TXD 6
  while (!Serial);
  // Send a test message
  rs485Serial.println("Hello from KinCony");
  // Wait for a short period
  delay(1000);
    String receivedMessage = "";
      char c = rs485Serial.read();
      receivedMessage += c;
    // Print the received message
    Serial.print("Received: ");
  delay(2000);
arduino ino file download:
.zip   RS485-Test.zip (Size: 754 bytes / Downloads: 22)
.zip   RS485-Test.ino.merged.zip (Size: 185.84 KB / Downloads: 22)
