Home Automation Power distribution Box - Lesson 3
Hi Team
In Lesson 3 - of Home Automation Power distribution Box - below is the link
New tab (kincony.com)
Kindly confirm the What is the "Amps " used for ( 12V DC contactor) in Hardware lists ?
Thanks & Regards,
Arshad
Thanks & Regards,
Arshad Abbas
Smile
already repiled to your another topic. 12v dc contact current is very low, just xx mA level.
Apms is unit for measurement of electric current, https://thedissertationhelp.co.uk/disser...topic/law/, it is produced by force of ohm.
.docx   Kincony_KC868-Server-Connection.docx (Size: 1.42 MB / Downloads: 580)
KC868 Server -- Output on/off - not working - seems to be some problem in wire connection please check attached photo of my wire connection
Thanks & Regards,
Arshad Abbas
Smile
Hi Please help I cannot get your code to compile I have installed libraries
Error message
Arduino: 1.8.12 (Windows 10), Board: "ESP32 Wrover Module, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), QIO, 80MHz, 921600, None"
In file included from C:\Users\malcolm\Downloads\PCF8574_library\PCF8574_library\examples\keyPressed_withInterrupt\keyPressed_withInterrupt.ino:8:0:
C:\Users\malcolm\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.6\cores\esp32/Arduino.h:184:12: error: 'std::round' has not been declared
using std::round;
exit status 1
Error compiling for board ESP32 Wrover Module.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Thanks Malcolm
(04-10-2023, 10:29 AM)ARSHAD Wrote: KC868 Server -- Output on/off - not working - seems to be some problem in wire connection please check attached photo of my wire connection
sorry, i don't understand your photo and what problem with you. you just see not work, what not work? what you have did? whether config by ESPHome???
(04-10-2023, 10:39 AM)Mal Wrote: Hi Please help I cannot get your code to compile I have installed libraries
Error message
using std::round;
exit status 1
Thanks Malcolm
we are using "NodeMcu32S", not "ESP32 Wrover Module". you should write your quesiton in details.
Server is not coming up - if i do wire connection like in attached photo
i have attached my smart board wire connection photo, please check
Thanks & Regards,
Arshad Abbas
Smile
cable is wrong. it should be:
Error message
using std::round;
exit status 1
Thanks Malcolm
Error message
using std::round;
exit status 1
Thanks Malcolm
How do I obtain the NodeMcu32S  board? it is not in my selection
