KC868-H32BS V1.50sp new firmware update
Update content:
1. support KC868-HA RS485 button adapter.
2. support "interlock" function for "output", that can use for curtain motor, protect your motor. some "interlock" output will never ON at the same time.
.zip   H32BS_V150SP_20221214.zip (Size: 56.28 KB / Downloads: 553)
thank you for updtae firmware for H32BS
i used mqtt in homassistant to control H32BS but  after update firmware  for H32BS  I noted homeassistant not response feedba  in spite of work H32BS
i used Home Assistant 2022.12.7
photo of configration
ok, we will test it after some days, then feedback to you.
How are you
Did you test it, I'm still waiting and h32bs is not working for me yet
Can you help me solve the problem
Thank you very much
we have checked, no problem, new home assistant MQTT syntax is updated. here is sample config file:
https://www.kincony.com/kc868-h32b-integ...-mqtt.html
I updated my configuration file as shown in the attachment
But it didn't work
Please use AnyDisk to help me
SAMPLE:
mqtt:
  broker: 192.168.1.42
  port: 1883
  username: mqtt
  password: NNNNNNNN
  - name: 'switch-1'
    unique_id: switch-1
    state_topic: 'relay32/XXXXXXXXXXXXXXXX/state'
    command_topic: 'relay32/XXXXXXXXXXXXXXXX/set'
    payload_on:  '{"relay1":{"on":1}}'
    payload_off:  '{"relay1":{"on":0}}'
    state_on: 1
    state_off: 0
.txt   NEW MQTT - Copy.txt (Size: 11.66 KB / Downloads: 337)
see HA log, what information have showed.
