esphome yaml file with ADC analog input 0-5v and 4-20mA for KC868-A8S/A8Sv2
  platform: ESP32
  sda: 4
  scl: 5
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
    address: 0x24
    address: 0x22
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      pcf8574: pcf8574_hub_in_1
      number: 4
      number: 5
      number: 6
      number: 7
  - platform: adc
    pin: 36
    name: "A8S A1 Voltage"
    update_interval: 5s
    attenuation: 11db
    filters:
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
          } else if (x <= 0.15) {
            return 0;
          } else {
            return x * 1.51;
  - platform: adc
    pin: 34
    name: "A8S A2 Voltage"
    update_interval: 5s
    attenuation: 11db
    filters:
      # - multiply: 1.51515
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
            return 0;
          } else {
            return x * 1.51;
  - platform: adc
    pin: 35
    name: "A8S A3 Current"
    update_interval: 5s
    unit_of_measurement: mA
    attenuation: 11db
    filters:
      - multiply: 6.66666666
  - platform: adc
    pin: 39
    name: "A8S A4 Current"
    update_interval: 5s
    attenuation: 11db
    filters:
yaml file download:
.txt   KC868-A8S-ha-config-ADC_voltage_current.txt (Size: 3.98 KB / Downloads: 873)
