Threads: 0
Sir, I want to turn ON / off just 2 Dimmers at one time without changing state of other 14 Dimmers on my D16.. i tried to put 2 commands at one time but it doesn't take it ..!! Is there any command which can change state of 2 or 3 Dimmers by one command ??
Threads: 1,560
First read the current value of each dimmer channel, and then use "multi channel output" command to control some channels output, keep the old values (before have read) for the channels you don't want to control.
