Cant make E16P work with apple homekit
Hello, so have bought an E16P esp32 board, too the file offer from the forum added them to Arduino IDE.
First issue was the <pcf8574.h> had to be in capitals in order to include the library.
Second and current issue am having is, error code: the list is way longer just added the first 2
In file included from C:\Users\nicol\OneDrive\Desktop\RealPushButtons\RealPushButtons.ino:7:
C:\Users\nicol\OneDrive\Desktop\RealPushButtons\DEV_LED.h: In function 'void PCF_WRITE(int, boolean)':
C:\Users\nicol\OneDrive\Desktop\RealPushButtons\DEV_LED.h:59:18: error: cannot convert 'PCF8574' to 'uint8_t' {aka 'unsigned char'}
    digitalWrite(pcfOUT_1, mPin - 1, !value);      //digitalWrite(ex1, (mPin-1), value);
In file included from C:\Users\nicol\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\cores\esp32/esp32-hal.h:83,
                from C:\Users\nicol\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\cores\esp32/Arduino.h:36,
                from C:\Users\nicol\AppData\Local\Temp\arduino\sketches\B825BA561FA7215E1D76DE33C6DE7CC9\sketch\RealPushButtons.ino.cpp:1:
C:\Users\nicol\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\cores\esp32/esp32-hal-gpio.h:75:27: note:  initializing argument 1 of 'void digitalWrite(uint8_t, uint8_t)'
void digitalWrite(uint8_t pin, uint8_t val);
.zip   RealPushButtons.zip (Size: 2.49 KB / Downloads: 712)
see here: https://github.com/HomeSpan/HomeSpan/discussions/394
