KCS firmware
#11
(09-18-2024, 07:55 PM)remiasz Wrote: Where to connect HC-SR04? It works on 5V and HT ports on 3V.
Maybe it's better to use 433M interface? 433M_T signal as trigger and DATA_R as echo. There is also 5V power supply on connector P2.
How to set PIN parameter?
Yes, HC-SR04 sensor output signal level is 5V or 0V. you can connect with 433MHz receiver data pin on PCB, that is 5v level.
one suggestion to improve your KCS firmware for KS868-AI:
add a possibility to send status of all inputs via UDP by defined time in setup, i.e. every 5 minutes.
It will help with integration to Loxone system, because now is sent only once by change and may happen, that UDP packet will be lost.
Thanks in advance.
Petr
wheher Loxone can decode message with all input state together? or only can update by single channel?
now whether input state changed , will auto upload message. because if alway loop, message will cost resource.
(10-07-2024, 01:07 AM)admin Wrote: wheher Loxone can decode message with all input state together? or only can update by single channel?
Loxone can parse the message  (RELAY-INPUT-255,1,\v ) but it should look like this to be able use the same virtual input:
RELAY-INPUT-255,1,1|RELAY-INPUT-255,2,0|RELAY-INPUT-255,3,1...
Or you can just repeat all single messages in loop. If the repeat interval will be in minutes, there will be small costs of resources.
ok, understand.
