ESPhome homeassistant
#11
Right, I am going in circles here with the same thing—where does the yaml file actually live, on the A6 itself?
Does it live in the main /homeassistant/configuration.yaml because that does not seem to work,
install esphome on home assistant. then create A6 device, paste our KC868-A6 yaml file.
Right - for all those people that are a bit slow like me there are a couple of additional steps here
1. Unpackage the board
2. Flash the Firmware to the board from this site
3. Install ESPHome Builder in HA, use the ESP Home Builder to generate the first part of the YAML file
4. You then have to download this to the A6, I had to use USB for the first time, then wireless worked after that. One you do this you lose access to the original config webpage and it's all through esphome from then on
5. The yaml files here need to be pasted in - not the whole thing, but at least from # Example configuration entry for ESP32 onwards, that will get you at least the 6 outputs and 6 inputs. Ill have to keep searching for the DA1, DA2 IO1, IO2 + A1,A2,A3,A4 config because they are not in the YAML file.
i think you can see these guide firstly if you are esphome beginner: https://www.kincony.com/forum/forumdisplay.php?fid=54
(01-14-2025, 07:45 AM)charmacf Wrote: is there anything i have to change in the yaml file?
i got it works thanks so much
HI
when I uploaded my yaml, KC868A16 is visible in HA but it does not respond to state changes when I control it from home assistant.
have you worked config ?
this is mine:
  friendly_name: kc868a16
    type: arduino
  encryption:
    key: "........................."
ota:
  - platform: esphome
    password: "2...................b628"
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
uart:
  - id: rs485
    tx_pin: GPIO13
    rx_pin: GPIO16
    baud_rate: 9600
remote_receiver:
    number: GPIO2
    ignore_strapping_warning: true
remote_transmitter:
    number: GPIO15
  carrier_duty_percent: 100%
  sda: GPIO4
  scl:
    number: GPIO5
  - id: inputs_1_8
    address: 0x22
  - id: inputs_9_16
    address: 0x21
  - id: outputs_1_8
    address: 0x24
  - id: outputs_9_16
    address: 0x25
      number: GPIO32
      number: GPIO33
      number: GPIO14
      pcf8574: inputs_1_8
      pcf8574: inputs_1_8
      pcf8574: inputs_1_8
      pcf8574: inputs_1_8
      pcf8574: inputs_1_8
      number: 4
      pcf8574: inputs_1_8
      number: 5
      pcf8574: inputs_1_8
      number: 6
      pcf8574: inputs_1_8
      number: 7
      pcf8574: inputs_9_16
      number: 4
      number: 5
      number: 6
      number: 7
      pcf8574: outputs_1_8
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      pcf8574: outputs_9_16
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
.txt   kc868a16mine.txt (Size: 5.73 KB / Downloads: 353)
take a photo, how you wire cable. maybe you have not connect with Vin terminal with dc12v. see the photo RED cable.
(01-31-2025, 12:26 AM)admin Wrote: take a photo, how you wire cable. maybe you have not connect with Vin terminal with dc12v. see the photo RED cable.
Yes, it WORKS, that was it, my mistake, sorry, I'm just starting the adventure.
THANK YOU
Can I connect reed switches and motion sensors to the inputs? and the bell button? I want to use it to control the lighting, and how can I make it so that, for example, the pulse from iput 1 controls output no. 1?
sure, any dry contact signal device can be connected with digital input ports.
you can download KCS firmware, then config IFTTT , let INPUT toggle OUTPUT. here is KCS v2 firmware online guide: https://www.kincony.com/esp32-kcsv2-firmware.html
