02-09-2025, 08:10 PM
In IFTTT Edit in the IF location I put id1 with a single click to THEN perform Custom Protocol1
When I do RUN I can send the command to the relay box and turn on R1.
When I physically do a single click on DI1 of the KC868-A16, nothing happens.
I changed it to HOLD ON and when I close DI1 I can already turn on R1 on the relay box
I changed it to TRUE and when I close ID1 momentarily Ican already turn on R1 on the relay box
In which situations is single click used?
I checked that we can change the time in ms of the double click, I also tried and never got any results
