RS485 Temperature and Humidity Sensor Modbus RTU
12-09-2024, 10:58 PM
check at here: https://www.kincony.com/forum/showthread.php?tid=6849
Online Store: https://shop.kincony.com Alibaba Store: https://kincony.en.alibaba.com/ (12-09-2024, 10:58 PM)admin Wrote: check at here: https://www.kincony.com/forum/showthread.php?tid=6849 How many of these sensors you can connect in same RS485 (in AIO)? Can you connect different type sensors at the same time? What is the maximum cable length for each sensor? Is shielded cable better after specific length?
02-08-2025, 12:36 PM
it according to your firmware. are you using kincony KCS firmware or config by ESPHome?
02-08-2025, 12:43 PM
I am using home assistant
02-09-2025, 02:53 AM
if you config by ESPHome yaml, one GPIO support multi sensors ,such as DS18B20. But one GPIO only connect with same type of sensor, can't connect with different sensor model.
it's not easy to say MAX cable , maybe 1 meter , maybe 5 meter, it according to your wire quality. shielded cable is better for long distance.
02-09-2025, 07:08 AM
So we can connect many SHT30 sensors on RS485 using ESPhome. I thought RS485 supports long cable (like 100 or 300m cable)
02-09-2025, 07:14 AM
yes, use RS485 sensor is better for long distance.
