I want to connect the temperature sensors ds18b20.
How many sensors can be connected to the S1 conector?
Do I need to connect an additional resistor to the 4,7K?
i don't know which board model you are asking?
maybe you are using KC868-A8, one 1-wire port only use by one sensor. it have pull up resistor on PCB already.
08-23-2025, 12:48 PM (This post was last modified: 08-23-2025, 12:51 PM by JuDie07.)
I think my problem fits in relatively well here: KC868-A8v3 and a ds18b20
I connected this directly without a resistor. I have also tried new ds18b20s.
None of them display anything, e.g. -100 °C. Connected to both S1 and S4 always the same!
KCS_A8V3_V3.11.7_beta_20250827-171730.zip (Size: 1.04 MB / Downloads: 472)
Tested A8v3 with 3pcs of DS18B20 sensors connect with S4,S3,S2 port.
set by KCS sensor webpage:
