F24 work with HAv2 with tuya app ESPHome yaml
  friendly_name: f24
  platformio_options:
    board_build.extra_flags:
      # WIFI_CONTROL_SELF_MODE = 0
      # WIFI_CONTROL_SELF_MODE = 1
  board: esp32-s3-devkitc-1
    type: arduino
external_components:
  - source:
      type: git
      ref: v1.3.0
  - source:
      type: git
      url: https://github.com/hzkincony/esphome-kc868-ha
      ref: v3.0.2
  encryption:
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO41
  interrupt_pin: GPIO2
  reset_pin: GPIO1
   - id: bus_a
     sda: 8
     scl: 18
     frequency: 400kHz
  - id: 'pcf8574_hub_out_1'  # for output channel 9-24
    i2c_id: bus_a
    address: 0x25
    pcf8575: true
  - id: 'pcf8574_hub_in_1'  # for digital input channel 1-16
    i2c_id: bus_a
    address: 0x24
    pcf8575: true
  - id: 'pcf8574_hub_out_in_2'  # for output channel 1-8  + (input 17-24)
    i2c_id: bus_a
    address: 0x26
    pcf8575: true
uart:
  - id: myuart1
    tx_pin: 16
    rx_pin: 17
    baud_rate: 9600
    debug:
      direction: BOTH
      dummy_receiver: false
  - id: tuya_mcu_uart
    tx_pin: GPIO39
    rx_pin: GPIO38
    baud_rate: 9600
tuya_wifi_mcu:
  # tuya mcu product id
  product_id: cchos3g1j2ucfbyd
  uart_id: tuya_mcu_uart
  wifi_reset_pin: 28
  wifi_led_pin: 16
kc868_ha:
  uart_id: myuart1
      pcf8574: pcf8574_hub_out_in_2
      number: 12
      mode: OUTPUT
  - platform: tuya_wifi_mcu
    dp_id: 1
    # hide from homeassistant ui
    internal: true
    bind_switch_id: "f24_output01"
      number: 13
      mode: OUTPUT
    dp_id: 2
    internal: true
    bind_switch_id: "f24_output02"
      number: 14
      mode: OUTPUT
    dp_id: 3
    internal: true
    bind_switch_id: "f24_output03"
      number: 15
      mode: OUTPUT
    dp_id: 4
    internal: true
    bind_switch_id: "f24_output04"
      number: 8
      mode: OUTPUT
    dp_id: 5
    internal: true
    bind_switch_id: "f24_output05"
      number: 9
      mode: OUTPUT
    dp_id: 6
    internal: true
    bind_switch_id: "f24_output06"
      number: 10
      mode: OUTPUT
    dp_id: 101
    internal: true
    bind_switch_id: "f24_output07"
      number: 11
      mode: OUTPUT
    dp_id: 102
    internal: true
    bind_switch_id: "f24_output08"
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
    dp_id: 103
    internal: true
    bind_switch_id: "f24_output09"
      mode: OUTPUT
    dp_id: 104
    internal: true
    bind_switch_id: "f24_output10"
      mode: OUTPUT
    dp_id: 105
    internal: true
    bind_switch_id: "f24_output11"
      mode: OUTPUT
    dp_id: 106
    internal: true
    bind_switch_id: "f24_output12"
      number: 4
      mode: OUTPUT
    dp_id: 107
    internal: true
    bind_switch_id: "f24_output13"
      number: 5
      mode: OUTPUT
    dp_id: 108
    internal: true
    bind_switch_id: "f24_output14"
      number: 6
      mode: OUTPUT
    dp_id: 109
    internal: true
    bind_switch_id: "f24_output15"
      number: 7
      mode: OUTPUT
    dp_id: 110
    internal: true
    bind_switch_id: "f24_output16"
      number: 8
      mode: OUTPUT
    dp_id: 126
    internal: true
    bind_switch_id: "f24_output17"
      number: 9
      mode: OUTPUT
    dp_id: 129
    internal: true
    bind_switch_id: "f24_output18"
      number: 10
      mode: OUTPUT
    dp_id: 130
    internal: true
    bind_switch_id: "f24_output19"
      number: 11
      mode: OUTPUT
    dp_id: 131
    internal: true
    bind_switch_id: "f24_output20"
      number: 12
      mode: OUTPUT
    dp_id: 132
    internal: true
    bind_switch_id: "f24_output21"
      number: 13
      mode: OUTPUT
    dp_id: 133
    internal: true
    bind_switch_id: "f24_output22"
      number: 14
      mode: OUTPUT
    dp_id: 134
    internal: true
    bind_switch_id: "f24_output23"
      number: 15
      mode: OUTPUT
    dp_id: 135
    internal: true
    bind_switch_id: "f24_output24"
  # The switch is used to control the D1~D6 level output on the KC868 HA board
  # bind_output is required. Corresponds to the BindOutput parameter in HA485_Ctrl software
  # Other parameters refer to: https://esphome.io/components/switch/index.html
  - platform: kc868_ha
    target_relay_controller_addr: 1
    switch_adapter_addr: 10
    bind_output: 1
    bind_output: 2
    bind_output: 3
    bind_output: 4
    bind_output: 5
    bind_output: 6
      pcf8574: pcf8574_hub_in_1
    dp_id: 111
    bind_binary_sensor_id: f24_input01
    internal: true
    dp_id: 112
    bind_binary_sensor_id: f24_input02
    internal: true
    dp_id: 113
    bind_binary_sensor_id: f24_input03
    internal: true
    dp_id: 114
    bind_binary_sensor_id: f24_input04
    internal: true
      number: 4
    dp_id: 115
    bind_binary_sensor_id: f24_input05
    internal: true
      number: 5
    dp_id: 116
    bind_binary_sensor_id: f24_input06
    internal: true
      number: 6
    dp_id: 117
    bind_binary_sensor_id: f24_input07
    internal: true
      number: 7
    dp_id: 118
    bind_binary_sensor_id: f24_input08
    internal: true
      number: 8
    dp_id: 119
    bind_binary_sensor_id: f24_input09
    internal: true
      number: 9
    dp_id: 120
    bind_binary_sensor_id: f24_input10
    internal: true
      number: 10
    dp_id: 121
    bind_binary_sensor_id: f24_input11
    internal: true
      number: 11
    dp_id: 122
    bind_binary_sensor_id: f24_input12
    internal: true
      number: 12
    dp_id: 123
    bind_binary_sensor_id: f24_input13
    internal: true
      number: 13
    dp_id: 124
    bind_binary_sensor_id: f24_input14
    internal: true
      number: 14
    dp_id: 125
    bind_binary_sensor_id: f24_input15
    internal: true
      number: 15
      number: 4
      number: 5
      number: 6
      number: 7
##pull-up resistance on PCB
      number: 48
      number: 47
      number: 21
      number: 15
## without resistance on PCB
      number: 13
      inverted: false
      number: 14
      inverted:  false
      number: 40
      inverted:  false
  # The binary_sensor corresponds to the state changes generated by K1~K6 on the KC868 HA board
  # Other parameters refer to: https://esphome.io/components/binary_sensor/index.html
    target_relay_controller_addr: 1 # Default value is 1, corresponds to the Target Relay Controller Addr parameter in HA485_Ctrl software
    switch_adapter_addr: 10 # Default value is 10, corresponds to the Switch Adapter Addr parameter in HA485_Ctrl software
    bind_output: 1 # Corresponds to the BindOutput parameter in HA485_Ctrl software
    bind_output: 2
    bind_output: 3
    bind_output: 4
    bind_output: 5
    bind_output: 6
  - platform: adc
    pin: 5
    name: "f24 A1 Voltage"
    update_interval: 5s
    attenuation: 11db
    filters:
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
          } else if (x <= 0.15) {
            return 0;
          } else {
            return x * 1.51;
  - platform: adc
    pin: 7
    name: "f24 A2 Voltage"
    update_interval: 5s
    attenuation: 11db
    filters:
      # - multiply: 1.51515
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
            return 0;
          } else {
            return x * 1.51;
  - platform: adc
    pin: 6
    name: "f24 A3 Current"
    update_interval: 5s
    unit_of_measurement: mA
    attenuation: 11db
    filters:
      - multiply: 6.66666666
  - platform: adc
    pin: 4
    name: "f24 A4 Current"
    update_interval: 5s
    attenuation: 11db
    filters:
web_server:
  port: 80
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    i2c_id: bus_a
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(roboto), "KinCony F24");
esphome yaml download:
.txt   HAv2-F24-Tuya.txt (Size: 20.91 KB / Downloads: 256)
