N10 - no KWH shown
Hi, I have just received my N10 and its all working - except the kwh is always zero in homeassistant and on the "monitor" page on kc3
I have tried the ESPhome firmware and the KC3 firmware > MQTT > Homeassistant with the same results - screenshots below for reference
When i used the ESPhome firmware i used this config file which mentions fixing the kwh  https://www.kincony.com/forum/attachment.php?aid=9373
I found this post - https://www.kincony.com/forum/showthread.php?tid=9107, and tried flashing via USBC port but it will not work - must this use the RS485?
Thank you
do you have downloaded newest ARM CPU firmware by USB-RS485 adapter?
(05-01-2026, 12:47 PM)admin Wrote: do you have downloaded newest ARM CPU firmware by USB-RS485 adapter?
No, i was trying to load the AMD firmware using the USB C port on the board (same way i put ESPHome on there) - I did not have a USB-RS485 adapter - but I have just ordered one. https://www.aliexpress.com/item/1005006071798894.html
What are the wire connections from the USB-RS485 adapter to the N10? please
connect USB-RS485 adapter to N10's RS485 port. Then download newest firmware:
https://www.kincony.com/forum/showthread.php?tid=9169
(05-01-2026, 11:32 PM)admin Wrote: connect USB-RS485 adapter to N10's RS485 port. Then download newest firmware:
Yes thank you - but i am meaning which cable / connector on the USB goes to A and B on the N10 RS485?
so for example
PHP Code:
USB screw         |   N10
(2nd from left) =    A
(4th from left} =    B
A-A B-B
