Yesterday, 03:22 AM
* Description:
* This Arduino program reads the state of a 16-channel PCF8574 I/O expander
* and prints the state of all input pins to the Serial Monitor. The state of
* each pin is represented as a bit in a 8-bit value, where each bit corresponds
* to an input pin. The program prints the input state in binary format.
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* - PCF8575 I2C Address: 0x22
#include "Arduino.h"
#include "PCF8574.h"
// Define I2C pins
#define I2C_SDA 8 // Define SDA pin
#define I2C_SCL 18 // Define SCL pin
// Set I2C address
PCF8574 pcf8574_IN1(0x22); // The I2C address of the PCF8575
Wire.begin(I2C_SDA, I2C_SCL); // Initialize I2C with defined SDA and SCL pins
pcf8574_IN1.pinMode(P0, INPUT);
pcf8574_IN1.pinMode(P1, INPUT);
pcf8574_IN1.pinMode(P2, INPUT);
pcf8574_IN1.pinMode(P3, INPUT);
pcf8574_IN1.pinMode(P4, INPUT);
pcf8574_IN1.pinMode(P5, INPUT);
pcf8574_IN1.pinMode(P6, INPUT);
pcf8574_IN1.pinMode(P7, INPUT);
pcf8574_IN1.begin(); // Initialize the PCF8575
Serial.println("KinCony 8 channel input state 0:ON 1:OFF");
uint16_t state = 0;
// Read the state of each pin (assuming 16 pins)
for (int pin = 0; pin < 8; pin++) {
if (pcf8574_IN1.digitalRead(pin)) {
state |= (1 << pin); // Set the bit for the active pin
Serial.print("Input state: ");
Serial.println(state, BIN); // Print the state of inputs in binary
delay(500); // Delay 500ms
2-digital-input.zip (Size: 890 bytes / Downloads: 3)
2-digital-input.ino.merged.zip (Size: 195.59 KB / Downloads: 4)
