12-21-2023, 02:26 AM
MB_HA_INA226.txt (Size: 11.36 KB / Downloads: 740)
platform: ESP32
- id: bus_a
sda: 15
scl: 4
frequency: 400kHz
- id: bus_b
sda: 5
scl: 16
frequency: 400kHz
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
- platform: ina226
address: 0x40
i2c_id: bus_a
shunt_resistance: 0.01 ohm
current:
name: "INA226 Current-1"
power:
bus_voltage:
name: "INA226 Bus Voltage-1"
shunt_voltage:
name: "INA226 Shunt Voltage-1"
max_current: 15A
update_interval: 5s
- platform: ina226
address: 0x41
i2c_id: bus_a
current:
name: "INA226 Current-2"
power:
bus_voltage:
name: "INA226 Bus Voltage-2"
shunt_voltage:
name: "INA226 Shunt Voltage-2"
max_current: 15A
update_interval: 5s
- platform: ina226
address: 0x42
i2c_id: bus_a
current:
name: "INA226 Current-3"
power:
bus_voltage:
name: "INA226 Bus Voltage-3"
shunt_voltage:
name: "INA226 Shunt Voltage-3"
max_current: 15A
update_interval: 5s
- platform: ina226
address: 0x43
i2c_id: bus_a
current:
name: "INA226 Current-4"
power:
bus_voltage:
name: "INA226 Bus Voltage-4"
shunt_voltage:
name: "INA226 Shunt Voltage-4"
max_current: 15A
update_interval: 5s
- platform: ina226
address: 0x44
i2c_id: bus_a
current:
name: "INA226 Current-5"
power:
bus_voltage:
name: "INA226 Bus Voltage-5"
shunt_voltage:
name: "INA226 Shunt Voltage-5"
max_current: 15A
update_interval: 5s
- platform: ina226
address: 0x45
i2c_id: bus_a
current:
name: "INA226 Current-6"
power:
bus_voltage:
name: "INA226 Bus Voltage-6"
shunt_voltage:
name: "INA226 Shunt Voltage-6"
max_current: 15A
update_interval: 5s
- platform: ina226
address: 0x46
i2c_id: bus_a
current:
name: "INA226 Current-7"
power:
bus_voltage:
name: "INA226 Bus Voltage-7"
shunt_voltage:
name: "INA226 Shunt Voltage-7"
max_current: 15A
update_interval: 5s
- platform: ina226
address: 0x47
i2c_id: bus_a
current:
name: "INA226 Current-8"
power:
bus_voltage:
name: "INA226 Bus Voltage-8"
shunt_voltage:
name: "INA226 Shunt Voltage-8"
max_current: 15A
update_interval: 5s
- platform: ina226
address: 0x40
i2c_id: bus_b
shunt_resistance: 0.1 ohm
current:
name: "INA226 Current-9"
power:
bus_voltage:
name: "INA226 Bus Voltage-9"
shunt_voltage:
name: "INA226 Shunt Voltage-9"
max_current: 15A
update_interval: 5s
- platform: ina226
address: 0x41
i2c_id: bus_b
current:
name: "INA226 Current-10"
power:
name: "INA226 Power-10"
bus_voltage:
name: "INA226 Bus Voltage-10"
shunt_voltage:
name: "INA226 Shunt Voltage-10"
max_current: 15A
update_interval: 5s
- platform: ina226
address: 0x42
i2c_id: bus_b
current:
name: "INA226 Current-11"
power:
name: "INA226 Power-11"
bus_voltage:
name: "INA226 Bus Voltage-11"
shunt_voltage:
name: "INA226 Shunt Voltage-11"
max_current: 15A
update_interval: 5s
- platform: ina226
address: 0x43
i2c_id: bus_b
current:
name: "INA226 Current-12"
power:
name: "INA226 Power-12"
bus_voltage:
name: "INA226 Bus Voltage-12"
shunt_voltage:
name: "INA226 Shunt Voltage-12"
max_current: 15A
update_interval: 5s
- platform: ina226
address: 0x44
i2c_id: bus_b
current:
name: "INA226 Current-13"
power:
name: "INA226 Power-13"
bus_voltage:
name: "INA226 Bus Voltage-13"
shunt_voltage:
name: "INA226 Shunt Voltage-13"
max_current: 15A
update_interval: 5s
- platform: ina226
address: 0x45
i2c_id: bus_b
current:
name: "INA226 Current-14"
power:
name: "INA226 Power-14"
bus_voltage:
name: "INA226 Bus Voltage-14"
shunt_voltage:
name: "INA226 Shunt Voltage-14"
max_current: 15A
update_interval: 5s
- platform: ina226
address: 0x46
i2c_id: bus_b
current:
name: "INA226 Current-15"
power:
name: "INA226 Power-15"
bus_voltage:
name: "INA226 Bus Voltage-15"
shunt_voltage:
name: "INA226 Shunt Voltage-15"
max_current: 15A
update_interval: 5s
- platform: ina226
address: 0x47
i2c_id: bus_b
current:
name: "INA226 Current-16"
power:
name: "INA226 Power-16"
bus_voltage:
name: "INA226 Bus Voltage-16"
shunt_voltage:
name: "INA226 Shunt Voltage-16"
max_current: 15A
update_interval: 5s
font:
- file: "gfonts://Roboto"
display:
- platform: ssd1306_i2c
i2c_id: bus_a
model: "SSD1306 128x64"
address: 0x3C
lambda: |-
it.printf(0, 0, id(roboto), "Monitor");
it.printf(0, 20, id(roboto), "V1: %.1fV", id(voltage_1).state);
it.printf(0, 40, id(roboto), "A1: %.1fA", id(current_1).state);
#external_components:
# - source:
# type: git
# url: https://github.com/hzkincony/esphome-universal-tcp
# ref: v1.0.0
#universal_tcp:
# id: universal_tcp1
# local_port: 8888 # esp32 will listen on this port
#interval:
# - interval: 5s
# then:
# - lambda: !lambda |-
# auto current = value_accuracy_to_string(id(current_1).state, 2);
# auto voltage = value_accuracy_to_string(id(voltage_1).state, 2);
# id(universal_tcp1).send_string_data("RELAY-GET_energy-255,1," + current + "," + voltage + ",OK");
# delay(28);
# current = value_accuracy_to_string(id(current_2).state, 2);
# voltage = value_accuracy_to_string(id(voltage_2).state, 2);
# id(universal_tcp1).send_string_data("RELAY-GET_energy-255,2," + current + "," + voltage + ",OK");
# delay(28);
# current = value_accuracy_to_string(id(current_3).state, 2);
# voltage = value_accuracy_to_string(id(voltage_3).state, 2);
# id(universal_tcp1).send_string_data("RELAY-GET_energy-255,3," + current + "," + voltage + ",OK");
# delay(28);
# current = value_accuracy_to_string(id(current_4).state, 2);
# voltage = value_accuracy_to_string(id(voltage_4).state, 2);
# id(universal_tcp1).send_string_data("RELAY-GET_energy-255,4," + current + "," + voltage + ",OK");
# delay(28);
# current = value_accuracy_to_string(id(current_5).state, 2);
# id(universal_tcp1).send_string_data("RELAY-GET_energy-255,5," + current + "," + voltage + ",OK");
# delay(28);
# current = value_accuracy_to_string(id(current_6).state, 2);
# voltage = value_accuracy_to_string(id(voltage_6).state, 2);
# id(universal_tcp1).send_string_data("RELAY-GET_energy-255,6," + current + "," + voltage + ",OK");
# delay(28);
# current = value_accuracy_to_string(id(current_7).state, 2);
# voltage = value_accuracy_to_string(id(voltage_7).state, 2);
# id(universal_tcp1).send_string_data("RELAY-GET_energy-255,7," + current + "," + voltage + ",OK");
# delay(28);
# current = value_accuracy_to_string(id(current_8).state, 2);
# voltage = value_accuracy_to_string(id(voltage_8).state, 2);
# id(universal_tcp1).send_string_data("RELAY-GET_energy-255,8," + current + "," + voltage + ",OK");
# delay(28);
# current = value_accuracy_to_string(id(current_9).state, 2);
# voltage = value_accuracy_to_string(id(voltage_9).state, 2);
# id(universal_tcp1).send_string_data("RELAY-GET_energy-255,9," + current + "," + voltage + ",OK");
# delay(28);
# current = value_accuracy_to_string(id(current_10).state, 2);
# voltage = value_accuracy_to_string(id(voltage_10).state, 2);
# id(universal_tcp1).send_string_data("RELAY-GET_energy-255,10," + current + "," + voltage + ",OK");
# delay(28);
# current = value_accuracy_to_string(id(current_11).state, 2);
# id(universal_tcp1).send_string_data("RELAY-GET_energy-255,11," + current + "," + voltage + ",OK");
# delay(28);
# current = value_accuracy_to_string(id(current_12).state, 2);
# voltage = value_accuracy_to_string(id(voltage_12).state, 2);
# id(universal_tcp1).send_string_data("RELAY-GET_energy-255,12," + current + "," + voltage + ",OK");
# delay(28);
# current = value_accuracy_to_string(id(current_13).state, 2);
# voltage = value_accuracy_to_string(id(voltage_13).state, 2);
# id(universal_tcp1).send_string_data("RELAY-GET_energy-255,13," + current + "," + voltage + ",OK");
# delay(28);
# current = value_accuracy_to_string(id(current_14).state, 2);
# voltage = value_accuracy_to_string(id(voltage_14).state, 2);
# id(universal_tcp1).send_string_data("RELAY-GET_energy-255,14," + current + "," + voltage + ",OK");
# delay(28);
# current = value_accuracy_to_string(id(current_15).state, 2);
# voltage = value_accuracy_to_string(id(voltage_15).state, 2);
# id(universal_tcp1).send_string_data("RELAY-GET_energy-255,15," + current + "," + voltage + ",OK");
# delay(28);
# current = value_accuracy_to_string(id(current_16).state, 2);
# voltage = value_accuracy_to_string(id(voltage_16).state, 2);
# id(universal_tcp1).send_string_data("RELAY-GET_energy-255,16," + current + "," + voltage + ",OK");
