Threads: 7
Available space is less than 1GB
how can i increase memory on LOCAL SERVER (RASPBERRY PI) – KC868-SERVER
can i used SD CARD ?
Threads: 1,560
sure , if you use home assistsant, you can plugin USB disk. then move data to USB disk, home assistant have this function for move data.
Threads: 7
Is it possible for me to use SD card ? as attach
Threads: 1,560
no can't, it's eMMC CM4, only use by eMMC.
Threads: 7
thank you for your support
Threads: 7
after i move to USB the system slow down
before that was perfect
i don’t know why this happened
any way to speed up the system?
thank you
Threads: 7
it should be the type of usb SSD or normal work fine
Threads: 7
Would be possible to connect SSD disk internally in the case of KC868-Server? I mean, under the black metal lid. Have you ever tried NVMe disks ?
