  • 3 Vote(s) - 5 Average
KC868-A8 ethernet work with home assistant by ESPHome configure
.txt   A8-esphome.txt (Size: 3.35 KB / Downloads: 1,427)
  platform: ESP32
  sda: 4
  scl: 5
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  # Optional manual IP
  manual_ip:
    static_ip: 192.168.1.199
    gateway: 192.168.1.1
    subnet: 255.255.255.0
    address: 0x24
    address: 0x22
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      pcf8574: pcf8574_hub_in_1
      number: 4
      number: 5
      number: 6
      number: 7
      number: 32
      number: 33
dallas:
  - pin: 14
  - platform: dallas
    address: 0x1c0000031edd2a28
(10-28-2022, 12:23 AM)admin Wrote: This is the error I get, I think it is happing when its compiling
INFO ESPHome 2023.12.9
INFO Reading configuration /config/esphome/alarm-io.yaml...
WARNING GPIO5 is a strapping PIN and should only be used for I/O with care.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
INFO Generating C++ source...
INFO Compiling app...
Processing kc868-a8 (board: esp32dev; framework: arduino; platform: platformio/espressif32@5.4.0)
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
- toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
Dependency Graph
|-- WiFi @ 2.0.0
|-- ESPmDNS @ 2.0.0
|-- Wire @ 2.0.0
Compiling .pioenvs/kc868-a8/src/esphome/components/api/api_connection.cpp.o
Compiling .pioenvs/kc868-a8/src/esphome/components/api/api_frame_helper.cpp.o
xtensa-esp32-elf-g++: fatal error: Killed signal terminated program cc1plus
compilation terminated.
*** [.pioenvs/kc868-a8/src/esphome/components/api/api_frame_helper.cpp.o] Error 1
*** [.pioenvs/kc868-a8/src/esphome/components/api/api_connection.cpp.o] Error 1
========================== [FAILED] Took 4.11 seconds ==========================
I don't know what is causing it?
  platform: ESP32
  sda: 4
  scl: 5
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  phy_addr: 0
  manual_ip:
    address: 0x24
    address: 0x22
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      number: 4
      number: 5
      number: 6
      number: 7
      number: 32
      number: 33
dallas:
  - pin: 14
  - platform: dallas
you can test with DHCP mode.
To integrate with Home Assistant, is it better to use KCS firmware and MQTT or do everything with ESPhome?
Regards
KCS is more easier to use many functions. ESPHome need you config the yaml file.
update for ESPHome v2025.11.0
  friendly_name: kc868-a8
    type: esp-idf
  sda: 4
  scl: 5
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  phy_addr: 0
  manual_ip:
    address: 0x24
    address: 0x22
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      number: 4
      number: 5
      number: 6
      number: 7
      number: 32
      number: 33
yaml file download:
.txt   A8-ESPHome-2025.11.0.txt (Size: 3.27 KB / Downloads: 278)
How to make use of IR modules?
I tried this without success:
No logs are ever printed on IR remote press
# IR
remote_receiver:
    number: GPIO2
    inverted: false
  dump: all          # prints all received codes to logs
  tolerance: 50%    # RF needs more tolerance than IR
remote_transmitter:
  pin: GPIO15
  carrier_duty_percent: 100%  # RF uses 100%, IR uses ~50%
# IR Modern approach - exposes learn/send directly in HA
#ir_rf_proxy:
#  - remote_receiver_id: rf_receiver
#    frequency: 433920000  # 433.92 MHz — tells HA this is RF not IR
#  - remote_transmitter_id: rf_transmitter
do you use IR or RF??
Sorry, I meant RF 433, as provided with your kit
do you have enabled LOG in ESPHome yaml?
another test way is download KCS v2 firmware, you can use RF.
