Kc868 server
Hi
I have difficulty seeing the entities output 1 -output 16
Input1-Input 16 of Kc868 server
my installation
homeassistant 8.5
.txt   code yaml configuration.txt (Size: 2.78 KB / Downloads: 447)
.txt   homeassistant log.txt (Size: 2.41 KB / Downloads: 1,035)
1kc868 server
1Kc868A16
2Kc868E16
update your yaml format as this file.
.txt   KC868-Server-home-assistant-MQTT_config_202212.txt (Size: 9.26 KB / Downloads: 434)
Hello, Could you help with config file for ESP32 of KC868 Server, i want to use GPIO4 for data led strip , but i can't manage to set up .
use WS2812B LED strip?
(04-01-2024, 10:26 PM)admin Wrote: use WS2812B LED strip?
Yes, and another question:
Does kc868 server work to configure the esp via wled app for data led strip?
connect your ws2812 led strip with ESP32's gpio, then config as : https://esphome.io/components/light/neopixelbus.html
Does kc868 server work to configure the esp via wled app for data led strip? Yes, it's ok.
here is video tour about KC868-Server work with WS2812B: https://www.kincony.com/forum/showthread.php?tid=1880
