Tuya_ESP32_Adapter virtual switch arduino source code for alexa and Google home speak
firmware BIN file download with address 0x0:
.zip   voice-control_0x0.zip (Size: 116.47 KB / Downloads: 969)
arduino source code:
#include <Arduino.h>
#include <TuyaWifi.h>
TuyaWifi my_device;
/* Current LED status */
unsigned char led_state = 0;
int key_pin = 27;
/* Data point define */
#define DPID_SWITCH_1   1
#define DPID_SWITCH_2   2
#define DPID_SWITCH_3   3
#define DPID_SWITCH_4   4
#define DPID_SWITCH_5   5
#define DPID_SWITCH_6   6
#define DPID_SWITCH_7   113
#define DPID_SWITCH_8   114
#define DPID_SWITCH_9   115
#define DPID_SWITCH_10  116
#define DPID_SWITCH_11  117
#define DPID_SWITCH_12  118
#define DPID_SWITCH_13  119
#define DPID_SWITCH_14  120
#define DPID_SWITCH_15  121
#define DPID_SWITCH_16  122
#define DPID_SWITCH_17  123
#define DPID_SWITCH_18  124
#define DPID_SWITCH_19  125
#define DPID_SWITCH_20  126
#define DPID_SWITCH_21  127
#define DPID_SWITCH_22  128
#define DPID_SWITCH_23  129
#define DPID_SWITCH_24  130
#define DPID_SWITCH_25  131
#define DPID_SWITCH_26  132
#define DPID_SWITCH_27  133
#define DPID_SWITCH_28  134
#define DPID_SWITCH_29  135
#define DPID_SWITCH_30  136
#define DPID_SWITCH_31  137
#define DPID_SWITCH_32  138
#define LED_WiFi  26
#define LED_User  33
unsigned char switch_1_state = 0;
unsigned char switch_2_state = 0;
unsigned char switch_3_state = 0;
unsigned char switch_4_state = 0;
unsigned char switch_5_state = 0;
unsigned char switch_6_state = 0;
unsigned char switch_7_state = 0;
unsigned char switch_8_state = 0;
unsigned char switch_9_state = 0;
unsigned char switch_10_state = 0;
unsigned char switch_11_state = 0;
unsigned char switch_12_state = 0;
unsigned char switch_13_state = 0;
unsigned char switch_14_state = 0;
unsigned char switch_15_state = 0;
unsigned char switch_16_state = 0;
unsigned char switch_17_state = 0;
unsigned char switch_18_state = 0;
unsigned char switch_19_state = 0;
unsigned char switch_20_state = 0;
unsigned char switch_21_state = 0;
unsigned char switch_22_state = 0;
unsigned char switch_23_state = 0;
unsigned char switch_24_state = 0;
unsigned char switch_25_state = 0;
unsigned char switch_26_state = 0;
unsigned char switch_27_state = 0;
unsigned char switch_28_state = 0;
unsigned char switch_29_state = 0;
unsigned char switch_30_state = 0;
unsigned char switch_31_state = 0;
unsigned char switch_32_state = 0;
*                                     dp type(TuyaDefs.h) : DP_TYPE_RAW, DP_TYPE_BOOL, DP_TYPE_VALUE, DP_TYPE_STRING, DP_TYPE_ENUM, DP_TYPE_BITMAP
unsigned char dp_array[][2] =
  {DPID_SWITCH_1, DP_TYPE_BOOL},{DPID_SWITCH_2, DP_TYPE_BOOL},{DPID_SWITCH_3, DP_TYPE_BOOL},{DPID_SWITCH_4, DP_TYPE_BOOL},{DPID_SWITCH_5, DP_TYPE_BOOL},{DPID_SWITCH_6, DP_TYPE_BOOL},
  {DPID_SWITCH_7, DP_TYPE_BOOL},{DPID_SWITCH_8, DP_TYPE_BOOL},{DPID_SWITCH_9, DP_TYPE_BOOL},{DPID_SWITCH_10, DP_TYPE_BOOL},{DPID_SWITCH_11, DP_TYPE_BOOL},{DPID_SWITCH_12, DP_TYPE_BOOL},
  {DPID_SWITCH_13, DP_TYPE_BOOL},{DPID_SWITCH_14, DP_TYPE_BOOL},{DPID_SWITCH_15, DP_TYPE_BOOL},{DPID_SWITCH_16, DP_TYPE_BOOL},{DPID_SWITCH_17, DP_TYPE_BOOL},{DPID_SWITCH_18, DP_TYPE_BOOL},
  {DPID_SWITCH_19, DP_TYPE_BOOL},{DPID_SWITCH_20, DP_TYPE_BOOL},{DPID_SWITCH_21, DP_TYPE_BOOL},{DPID_SWITCH_22, DP_TYPE_BOOL},{DPID_SWITCH_23, DP_TYPE_BOOL},{DPID_SWITCH_24, DP_TYPE_BOOL},
  {DPID_SWITCH_25, DP_TYPE_BOOL},{DPID_SWITCH_26, DP_TYPE_BOOL},{DPID_SWITCH_27, DP_TYPE_BOOL},{DPID_SWITCH_28, DP_TYPE_BOOL},{DPID_SWITCH_29, DP_TYPE_BOOL},{DPID_SWITCH_30, DP_TYPE_BOOL},
{DPID_SWITCH_31, DP_TYPE_BOOL},{DPID_SWITCH_32, DP_TYPE_BOOL},
unsigned char pid[] = {"tsfqvoyi6pxqxq6o"};
/* last time */
unsigned long last_time = 0;
void setup()
  // Serial with tuyawifi
  Serial.begin(9600,SERIAL_8N1,14,13);
  pinMode(LED_WiFi, OUTPUT);
  digitalWrite(LED_WiFi, LOW);
  pinMode(LED_User, OUTPUT);
  digitalWrite(LED_User, LOW);
  //Initialize networking keys.
  my_device.init(pid, mcu_ver);
  my_device.set_dp_cmd_total(dp_array, 1);
  last_time = millis();
void loop()
  my_device.uart_service();
  //Enter the connection network mode when Pin7 is pressed.
    delay(80);
      if (led_state == LOW) {
        led_state = HIGH;
      } else {
        led_state = LOW;
      digitalWrite(LED_WiFi, led_state);
  delay(10);
* @param {unsigned char} dpid
* @return {unsigned char}
  switch(dpid) {
    case DPID_SWITCH_1:
      switch_1_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      //Status changes should be reported.
      my_device.mcu_dp_update(DPID_SWITCH_1, switch_1_state, length);
    break;
    case DPID_SWITCH_2:
      switch_2_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_2, switch_2_state, length);
    break;
    case DPID_SWITCH_3:
      switch_3_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_3, switch_3_state, length);
    break;
    case DPID_SWITCH_4:
      switch_4_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_4, switch_4_state, length);
    break;
    case DPID_SWITCH_5:
      switch_5_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_5, switch_5_state, length);
    break;
    case DPID_SWITCH_6:
      switch_6_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_6, switch_6_state, length);
    break;
    case DPID_SWITCH_7:
      switch_7_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_7, switch_7_state, length);
    break;
    case DPID_SWITCH_8:
      switch_8_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_8, switch_8_state, length);
    break;
    case DPID_SWITCH_9:
      switch_9_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_9, switch_9_state, length);
    break;
    case DPID_SWITCH_10:
      switch_10_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_10, switch_10_state, length);
    break;
    case DPID_SWITCH_11:
      switch_11_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_11, switch_11_state, length);
    break;
    case DPID_SWITCH_12:
      switch_12_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_12, switch_12_state, length);
    break;
    case DPID_SWITCH_13:
      switch_13_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_13, switch_13_state, length);
    break;
    case DPID_SWITCH_14:
      switch_14_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_14, switch_14_state, length);
    break;
    case DPID_SWITCH_15:
      switch_15_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_15, switch_15_state, length);
    break;
    case DPID_SWITCH_16:
      switch_16_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_16, switch_16_state, length);
    break;
    case DPID_SWITCH_17:
      switch_17_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_17, switch_17_state, length);
    break;
    case DPID_SWITCH_18:
      switch_18_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_18, switch_18_state, length);
    break;
    case DPID_SWITCH_19:
      switch_19_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_19, switch_19_state, length);
    break;
    case DPID_SWITCH_20:
      switch_20_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_20, switch_20_state, length);
    break;
    case DPID_SWITCH_21:
      switch_21_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_21, switch_21_state, length);
    break;
    case DPID_SWITCH_22:
      switch_22_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_22, switch_22_state, length);
    break;
    case DPID_SWITCH_23:
      switch_23_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_23, switch_23_state, length);
    break;
    case DPID_SWITCH_24:
      switch_24_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_24, switch_24_state, length);
    break;
    case DPID_SWITCH_25:
      switch_25_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_25, switch_25_state, length);
    break;
    case DPID_SWITCH_26:
      switch_26_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_26, switch_26_state, length);
    break;
    case DPID_SWITCH_27:
      switch_27_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_27, switch_27_state, length);
    break;
    case DPID_SWITCH_28:
      switch_28_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_28, switch_28_state, length);
    break;
    case DPID_SWITCH_29:
      switch_29_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_29, switch_29_state, length);
    break;
    case DPID_SWITCH_30:
      switch_30_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_30, switch_30_state, length);
    break;
    case DPID_SWITCH_31:
      switch_31_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_31, switch_31_state, length);
    break;
    case DPID_SWITCH_32:
      switch_32_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_32, switch_32_state, length);
    break;
    default:break;
  return TY_SUCCESS;
* @param {*}
* @return {*}
void dp_update_all(void)
  my_device.mcu_dp_update(DPID_SWITCH_1, switch_1_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_2, switch_2_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_3, switch_3_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_4, switch_4_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_5, switch_5_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_6, switch_6_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_7, switch_7_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_8, switch_8_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_9, switch_9_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_10, switch_10_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_11, switch_11_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_12, switch_12_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_13, switch_13_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_14, switch_14_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_15, switch_15_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_16, switch_16_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_17, switch_17_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_18, switch_18_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_19, switch_19_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_20, switch_20_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_21, switch_21_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_22, switch_22_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_23, switch_23_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_24, switch_24_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_25, switch_25_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_26, switch_26_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_27, switch_27_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_28, switch_28_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_29, switch_29_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_30, switch_30_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_31, switch_31_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_32, switch_32_state, 1);
Puedo hacer Toggle con tuya?
just for ON/OFF control. But you can modify the source code for TOGGLE.
(02-24-2024, 10:33 PM)admin Wrote: just for ON/OFF control. But you can modify the source code for TOGG
which part the code can change?
just modify every control relay's function in arduino code. If you are not familiar with Arduino, it is not recommended that you modify it.
