KC868-AM work with DS18B20 DHT11 sensor ESPHome yaml
    type: arduino
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  manual_ip:
    static_ip: 192.168.1.211
    gateway: 192.168.1.1
    subnet: 255.255.255.0
    pin: 15
    inverted: False
  - platform: dht
    pin: 33
    temperature:
    humidity:
      name: "Living Room Humidity"
    update_interval: 10s
  - platform: dallas
    dallas_id: hub_1
    address: 0xde0b23585c42fb28
  - platform: dallas
    dallas_id: hub_1
    address: 0xd20b2210b8edbd28
  - platform: dallas
    dallas_id: hub_3
    address: 0x690b2210c2ff4a28
  - platform: dallas
    dallas_id: hub_2
    address: 0x3f0b2210c07d1b28
dallas:
  - pin: 5
  - pin: 13
    update_interval: 20s
  - pin: 14
    update_interval: 30s
yaml file download:
.txt   esphome_AM.txt (Size: 1.13 KB / Downloads: 480)
This example is no longer valid. Please see https://esphome.io/components/sensor/dallas_temp
Can you provide an updated example for DS18B20 temp sensor.
see this link: https://www.kincony.com/forum/showthread.php?tid=6944
it's the newest yaml i have tested.
I git it working. This is the code I am using and currently have only 1 sensor per input so no address.
    pin: 15
    inverted: False
  - platform: dallas_temp
    one_wire_id: hub_1
    one_wire_id: hub_2
    one_wire_id: hub_3
    one_wire_id: hub_4
    name: "Main Boiler Temp"
one_wire:
    pin: GPIO05
    pin: GPIO13
    pin: GPIO14
    pin: GPIO33
ok, thanks share your code.
