07-14-2024, 09:12 PM
Hardware setup: Kincony MiniServer running homeassistant connected to kincony A6 board (slave) via RS485.
Created a Modbus-switch in the Mini Server yaml configuration pointing to relay 1 onto the A6 board.
Problem: when I switch on or off the modbus switch at home assistant sometimes the relay goes on or off immediately, sometimes after some seconds (<10 more or less). The dashboard at home assistant update the situation after some seconds (<10 more or less), not immediately.
Sometimes the relay is on but the dashboard show it off, and sometimes viceversa.
The more strange situation happen if I change the master of the modbus. I tried to use another A6 board as master and in this case all it's running ok and there are no delay. It's all immediate.
I made a video for better explain this. I don't want to abuse of this forum, so could I post the video here ?
In the mean time I attach my yaml files.
configuration.pdf (Size: 32.4 KB / Downloads: 834)
kc868-a6-exp3.pdf (Size: 36.64 KB / Downloads: 1,479)
