KC868-AIO LOXONE
Hi ,
i am trying to integrate my KC868-AIO into my loxone system .
i am new to this so i am having some problems.
i have done this so far :
pc and Kincony AIO are connected to the same acces point.
i can acces the AIO tru ESPhome .
when i configure the AIO there i can find the AIO in my wireless network
i was able to connect with the download tool so the firmware V2 could be installed but there i get stuck
the download is succesful
but then i can not do anything .
if i use the scan device tool i can not find the kincony
and the wireless signal of the kincony is gone until i re install it with the esphome "install for first use".
i am sure i am making some silly fault but unexperienced me is stuck at the moment Smile
1. the newest KCS firmware is v2.2.2, here is download link:
https://www.kincony.com/forum/showthread.php?tid=3791
2. when you download, your address is wrong, not "0x10000" , it should be"0x0"
thanks ,
i re uploaded V2.2 into my unit on adress 0x0 .
but still i find no way to connect trough eternet or wifi .
what i tried so far :
i made my computer ip static in the same range as the AIO so 192.168.1.101
i used the scan device list but when hitting scan no results
AIO is connected with ethernet to a switch pc is connected to the same switch
also pc and AIO are connected trough usb
i also tried to reset  ESP32 GPIO0 (am i right to assume thats the "download" button , the top one next to the usb C input) by holding to 10+ seconds but no wifi pops up
1. after download need re power on of board.
2. KC868-AIO and your PC should connect to same router.
how to use KCS v2, here is online guide: https://www.kincony.com/esp32-kcsv2-firmware.html
hi , i havent worked on my system in a long time but did manage to get some work into it recently .
what i done so far :
my setup :
KC868-AIO board
Loxone miniserver V1
i made a virtual ESP home using virtualbox ( will be changing that to a raspberry pi unit or kincony miniserver  in the future)
uploaded a new Yaml file to ESPhome with the loxone code writen into it and aletered all inputs and outputs for loxone
i attached the yaml file also
then i did open my loxone config file and imported the UDP inputs and outputs
but i cant get both to communicate with eathother . what am i doing wrong ?
.zip   esphome-web-8af0f0 (2).zip (Size: 2.94 KB / Downloads: 361)
do you want KC868-AIO's digital input ports and digital output ports integrate to Loxone miniserver?
if YES, when i have free time, have a test.
(12-01-2024, 11:54 PM)admin Wrote: do you want KC868-AIO's digital input ports and digital output ports integrate to Loxone miniserver?
Hi , Yes , thats right , i want to use the input and output ports in Loxone .
thanks for wanting to take a look at it .
i have tessted KC868-AIO work with Loxone Miniserver, it's OK.
i have write the yaml with 1 channel output and 1 channel input demo for you.  you can enable more channels for Loxone Miniserver.
    type: arduino
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
   - id: bus_a
     sda: 4
     scl: 16
external_components:
  - source:
      type: git
      url: https://github.com/hzkincony/esphome-loxone
      ref: v1.2.1
  - id: 'pcf8574_hub_out_1'  # for output channel 1-16
    i2c_id: bus_a
    address: 0x24
    pcf8575: true
  - id: 'pcf8574_hub_out_2'  # for output channel 17-32
    i2c_id: bus_a
    address: 0x25
    pcf8575: true
  - id: 'pcf8574_hub_out_in_3'  # for output channel 33-38  + (input 49-58)
    i2c_id: bus_a
    address: 0x26
    pcf8575: true
  - id: 'pcf8574_hub_in_1'  # for input channel 1-16
    i2c_id: bus_a
    address: 0x21
    pcf8575: true
  - id: 'pcf8574_hub_in_2'  # for input channel 17-32
    i2c_id: bus_a
    address: 0x22
    pcf8575: true
  - id: 'pcf8574_hub_in_3'  # for input channel 33-48
    i2c_id: bus_a
    address: 0x23
    pcf8575: true
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
    on_turn_on:
      - lambda: !lambda |-
          id(loxone1).send_string_data("RELAY-SET-255,1,1,OK");
    on_turn_off:
          id(loxone1).send_string_data("RELAY-SET-255,1,0,OK");
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      number: 8
      mode: OUTPUT
      number: 9
      mode: OUTPUT
      number: 10
      mode: OUTPUT
      number: 11
      mode: OUTPUT
      number: 12
      mode: OUTPUT
      number: 13
      mode: OUTPUT
      number: 14
      mode: OUTPUT
      number: 15
      mode: OUTPUT
      pcf8574: pcf8574_hub_out_2
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      number: 8
      mode: OUTPUT
      number: 9
      mode: OUTPUT
      number: 10
      mode: OUTPUT
      number: 11
      mode: OUTPUT
      number: 12
      mode: OUTPUT
      number: 13
      mode: OUTPUT
      number: 14
      mode: OUTPUT
      number: 15
      mode: OUTPUT
      pcf8574: pcf8574_hub_out_in_3
      number: 12
      mode: OUTPUT
      number: 13
      mode: OUTPUT
cd74hc4067:
  - id: cd74hc4067_1
    pin_s0:
      number: 8
      mode: OUTPUT
    pin_s1:
      number: 9
      mode: OUTPUT
    pin_s2:
      number: 10
      mode: OUTPUT
    pin_s3:
      number: 11
      mode: OUTPUT
one_wire:
    pin: GPIO5
  - platform: dallas_temp
    address: 0xec0921405caae128
    update_interval: 10s
  - platform: adc
    pin: 36
    update_interval: never
    attenuation: 11db
  - platform: adc
    pin: 39
    update_interval: 5s
    attenuation: 11db
  - platform: adc
    pin: 34
    update_interval: 5s
    attenuation: 11db
  - platform: adc
    pin: 35
    update_interval: 5s
    attenuation: 11db
  - platform: cd74hc4067
    sensor: adc36
    update_interval: 5s
    sensor: adc36
    update_interval: 5s
    sensor: adc36
    update_interval: 5s
    sensor: adc36
    update_interval: 5s
    number: 4
    sensor: adc36
    update_interval: 5s
    number: 5
    sensor: adc36
    update_interval: 5s
    number: 6
    sensor: adc36
    update_interval: 5s
    number: 7
    sensor: adc36
    update_interval: 5s
    number: 8
    sensor: adc36
    update_interval: 5s
    number: 9
    sensor: adc36
    update_interval: 5s
    number: 10
    sensor: adc36
    update_interval: 5s
    number: 11
    sensor: adc36
    update_interval: 5s
    number: 12
    sensor: adc36
    update_interval: 5s
    number: 13
    sensor: adc36
    update_interval: 5s
    number: 14
    sensor: adc36
    update_interval: 5s
    number: 15
    sensor: adc36
    update_interval: 5s
# Individual inputs
      pcf8574: pcf8574_hub_in_1
    on_press:
          id(loxone1).send_string_data("RELAY-GET_INPUT-255,1,1,OK");
    on_release:
          id(loxone1).send_string_data("RELAY-GET_INPUT-255,1,0,OK");
      number: 4
      number: 5
      number: 6
      number: 7
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_in_2
      number: 4
      number: 5
      number: 6
      number: 7
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_in_3
      number: 4
      number: 5
      number: 6
      number: 7
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      number: 4
      number: 5
      number: 6
      number: 7
      number: 14
      number: 15
pca9685:
    frequency: 500
output:
  - platform: pca9685
    pca9685_id: 'pca9685_hub'
    channel: 0
  - platform: pca9685
    channel: 1
  - platform: pca9685
    channel: 2
  - platform: pca9685
    channel: 3
  - platform: pca9685
    channel: 4
  - platform: pca9685
    channel: 5
  - platform: pca9685
    channel: 6
  - platform: pca9685
    channel: 7
  - platform: pca9685
    channel: 8
  - platform: pca9685
    channel: 9
  - platform: pca9685
    channel: 10
  - platform: pca9685
    channel: 11
  - platform: pca9685
    channel: 12
  - platform: pca9685
    channel: 13
  - platform: pca9685
    channel: 14
  - platform: pca9685
    channel: 15
light:
  - platform: monochromatic
    output: PWM0
    output: PWM1
    output: PWM2
    output: PWM3
    output: PWM4
    output: PWM5
    output: PWM6
    output: PWM7
    output: PWM8
    output: PWM9
    output: PWM10
    output: PWM11
    output: PWM12
    output: PWM13
    output: PWM14
    output: PWM15
  - platform: rgbw
    red: PWM1
    green: PWM2
    blue: PWM3
    white: PWM4
web_server:
  port: 80
loxone:
  protocol: udp
  loxone_ip: "192.168.3.108"
  loxone_port: 9999
  listen_port: 8888
  delimiter: "\n"
  send_buffer_length: 64
  on_string_data:
    # - logger.log:
    #     format: "on_string_data, data=%s"
    #     args: [ data.c_str() ]
        if (data == "RELAY-SET-255,1,1") {
          id(aio_light1).turn_on();
        } else if (data == "RELAY-SET-255,1,0") {
          id(aio_light1).turn_off();
here is yaml file:
.txt   AIO-Loxone-ymal.txt (Size: 21.74 KB / Downloads: 296)
turn ON output1 by home assistant web page, then Loxone will update:
trigger INPUT1 with GND:
Then will feedback to Loxone config:
Loxone project download:
https://www.kincony.com/forum/attachment.php?aid=3439
Hi ,
thanks for the help ,
i got further but i am running in some new problems:
if i press a virtual button in the loxone app ,
i get this state on esphome :
this is the screen i get at the same time on loxone config :
i think that looks good , but in real life the led of output 4 on the AIO does not turn on . ( i also tested with different outputs but that is the same)
when i press the switch myself in esphome the output does turn on
edit : it seems that i was wrong . the unit freezes when it sends out to the loxone for a state change . it is normaly contanstantly checking the sensor states but when changing one of the relais states and sending it to the loxone it freezes for a little longer than 2 minutes. it also occurs that the lef of the outputs flickers ones for half of a second and then turns off
edit edit : got it solved for the moment ; i changed max output buffer for loxone to 32 instead of 64 and added 100ms delay to all on or off comands for the relais . works like a charm
work well now?
