09-05-2022, 03:35 AM
(This post was last modified: 09-15-2022, 02:34 AM by KinCony Support.)
[Arduino IDE demo source code for KC868-A16]--#11-KC868-A16_Ethernet_Web_server_code
Refer to code #11 of A8 for download methods
KC868-A16_Web_Server_Eth.zip (Size: 413.26 KB / Downloads: 1,558)
* Create Your own Ethernet-WebServer for KC868-A32 Smart Controller*
* https://www.kincony.com ***********
#include "PCF8574.h"
#define DEBUG_ETHERNET_WEBSERVER_PORT Serial
// Debug Level from 0 to 4
#define _ETHERNET_WEBSERVER_LOGLEVEL_ 3
WiFiServer server(80);
// Select the IP address according to your local network
IPAddress myIP(192, 168, 1, 232);
IPAddress myGW(192, 168, 1, 1);
IPAddress mySN(255, 255, 255, 0);
// Google DNS Server IP
IPAddress myDNS(8, 8, 8, 8);
// Current time
// Previous time
int flag_read_di=0;
String header;
TwoWire I2Cone = TwoWire(0);
//TwoWire I2Ctwo = TwoWire(1);
// Set relay output i2c address
PCF8574 pcf8574_R1(&I2Cone, 0x3C, 4, 5);
PCF8574 pcf8574_R2(&I2Cone, 0x3D, 4, 5);
//PCF8574 pcf8574_R3(&I2Ctwo, 0x21, 15, 13);
//PCF8574 pcf8574_R4(&I2Ctwo, 0x22, 15, 13);
PCF8574 pcf8574_I1(&I2Cone, 0x3A, 4, 5);
PCF8574 pcf8574_I2(&I2Cone, 0x39, 4, 5);
//PCF8574 pcf8574_I3(&I2Cone, 0x21, 4, 5);
//PCF8574 pcf8574_I4(&I2Cone, 0x22, 4, 5);
String relay32state = "off";// state of relay32*/
void setup()
pcf8574_R1.pinMode(P0, OUTPUT);
pcf8574_R1.pinMode(P1, OUTPUT);
pcf8574_R1.pinMode(P2, OUTPUT);
pcf8574_R1.pinMode(P3, OUTPUT);
pcf8574_R1.pinMode(P4, OUTPUT);
pcf8574_R1.pinMode(P5, OUTPUT);
pcf8574_R1.pinMode(P6, OUTPUT);
pcf8574_R1.pinMode(P7, OUTPUT);
pcf8574_R2.pinMode(P0, OUTPUT);
pcf8574_R2.pinMode(P1, OUTPUT);
pcf8574_R2.pinMode(P2, OUTPUT);
pcf8574_R2.pinMode(P3, OUTPUT);
pcf8574_R2.pinMode(P4, OUTPUT);
pcf8574_R2.pinMode(P5, OUTPUT);
pcf8574_R2.pinMode(P6, OUTPUT);
pcf8574_R2.pinMode(P7, OUTPUT);
pcf8574_R3.pinMode(P0, OUTPUT);
pcf8574_R3.pinMode(P1, OUTPUT);
pcf8574_R3.pinMode(P2, OUTPUT);
pcf8574_R3.pinMode(P3, OUTPUT);
pcf8574_R3.pinMode(P4, OUTPUT);
pcf8574_R3.pinMode(P5, OUTPUT);
pcf8574_R3.pinMode(P6, OUTPUT);
pcf8574_R3.pinMode(P7, OUTPUT);
pcf8574_R4.pinMode(P0, OUTPUT);
pcf8574_R4.pinMode(P1, OUTPUT);
pcf8574_R4.pinMode(P2, OUTPUT);
pcf8574_R4.pinMode(P3, OUTPUT);
pcf8574_R4.pinMode(P4, OUTPUT);
pcf8574_R4.pinMode(P5, OUTPUT);
pcf8574_R4.pinMode(P6, OUTPUT);
pcf8574_R4.pinMode(P7, OUTPUT);*/
Serial.print("Init pcf8574_R1...");
if (pcf8574_R1.begin()){
Serial.println("PCF8574_R1_OK");
}else{
Serial.println("PCF8574_R1_KO");
Serial.print("Init pcf8574_R2...");
if (pcf8574_R2.begin()){
Serial.println("PCF8574_R2_OK");
}else{
Serial.println("PCF8574_R2_KO");
Serial.print("Init pcf8574_R3...");
if (pcf8574_R3.begin()){
Serial.println("PCF8574_R3_OK");
}else{
Serial.println("PCF8574_R3_KO");
Serial.print("Init pcf8574_R4...");
if (pcf8574_R4.begin()){
Serial.println("PCF8574_R4_OK");
}else{
Serial.println("PCF8574_R4_KO");
pcf8574_I1.pinMode(P0, INPUT);
pcf8574_I1.pinMode(P1, INPUT);
pcf8574_I1.pinMode(P2, INPUT);
pcf8574_I1.pinMode(P3, INPUT);
pcf8574_I1.pinMode(P4, INPUT);
pcf8574_I1.pinMode(P5, INPUT);
pcf8574_I1.pinMode(P6, INPUT);
pcf8574_I1.pinMode(P7, INPUT);
pcf8574_I2.pinMode(P0, INPUT);
pcf8574_I2.pinMode(P1, INPUT);
pcf8574_I2.pinMode(P2, INPUT);
pcf8574_I2.pinMode(P3, INPUT);
pcf8574_I2.pinMode(P4, INPUT);
pcf8574_I2.pinMode(P5, INPUT);
pcf8574_I2.pinMode(P6, INPUT);
pcf8574_I2.pinMode(P7, INPUT);
pcf8574_I3.pinMode(P0, INPUT);
pcf8574_I3.pinMode(P1, INPUT);
pcf8574_I3.pinMode(P2, INPUT);
pcf8574_I3.pinMode(P3, INPUT);
pcf8574_I3.pinMode(P4, INPUT);
pcf8574_I3.pinMode(P5, INPUT);
pcf8574_I3.pinMode(P6, INPUT);
pcf8574_I3.pinMode(P7, INPUT);
pcf8574_I4.pinMode(P0, INPUT);
pcf8574_I4.pinMode(P1, INPUT);
pcf8574_I4.pinMode(P2, INPUT);
pcf8574_I4.pinMode(P3, INPUT);
pcf8574_I4.pinMode(P4, INPUT);
pcf8574_I4.pinMode(P5, INPUT);
pcf8574_I4.pinMode(P6, INPUT);
pcf8574_I4.pinMode(P7, INPUT);*/
if (pcf8574_I1.begin()){
Serial.println("pcf8574_I1_OK");
}else{
Serial.println("pcf8574_I1_KO");
if (pcf8574_I2.begin()){
Serial.println("pcf8574_I2_OK");
}else{
Serial.println("pcf8574_I2_KO");
Serial.print("Init pcf8574_I3...");
if (pcf8574_I3.begin()){
Serial.println("pcf8574_I3_OK");
}else{
Serial.println("pcf8574_I3_KO");
Serial.print("Init pcf8574_I4...");
if (pcf8574_I4.begin()){
Serial.println("pcf8574_I4_OK");
}else{
Serial.println("pcf8574_I4_KO");
pcf8574_R1.digitalWrite(P0, HIGH);
pcf8574_R1.digitalWrite(P1, HIGH);
pcf8574_R1.digitalWrite(P2, HIGH);
pcf8574_R1.digitalWrite(P3, HIGH);
pcf8574_R1.digitalWrite(P4, HIGH);
pcf8574_R1.digitalWrite(P5, HIGH);
pcf8574_R1.digitalWrite(P6, HIGH);
pcf8574_R1.digitalWrite(P7, HIGH);
pcf8574_R2.digitalWrite(P0, HIGH);
pcf8574_R2.digitalWrite(P1, HIGH);
pcf8574_R2.digitalWrite(P2, HIGH);
pcf8574_R2.digitalWrite(P3, HIGH);
pcf8574_R2.digitalWrite(P4, HIGH);
pcf8574_R2.digitalWrite(P5, HIGH);
pcf8574_R2.digitalWrite(P6, HIGH);
pcf8574_R2.digitalWrite(P7, HIGH);
pcf8574_R3.digitalWrite(P0, HIGH);
pcf8574_R3.digitalWrite(P1, HIGH);
pcf8574_R3.digitalWrite(P2, HIGH);
pcf8574_R3.digitalWrite(P3, HIGH);
pcf8574_R3.digitalWrite(P4, HIGH);
pcf8574_R3.digitalWrite(P5, HIGH);
pcf8574_R3.digitalWrite(P6, HIGH);
pcf8574_R3.digitalWrite(P7, HIGH);
pcf8574_R4.digitalWrite(P0, HIGH);
pcf8574_R4.digitalWrite(P1, HIGH);
pcf8574_R4.digitalWrite(P2, HIGH);
pcf8574_R4.digitalWrite(P3, HIGH);
pcf8574_R4.digitalWrite(P4, HIGH);
pcf8574_R4.digitalWrite(P5, HIGH);
pcf8574_R4.digitalWrite(P6, HIGH);
pcf8574_R4.digitalWrite(P7, HIGH);*/
while (!Serial);
WT32_ETH01_onEvent();
// eth_phy_type_t type=ETH_PHY_TYPE, eth_clock_mode_t clk_mode=ETH_CLK_MODE);
WT32_ETH01_waitForConnect();
// start the web server on port 80
server.begin();
void loop()
// listen for incoming clients
WiFiClient client = server.available();
currentTime = millis();
previousTime = currentTime;
header += c;
client.println();
// turns 32 relays on and off
else if (header.indexOf("GET /7/on") >= 0) {relay7state = "on";pcf8574_R1.digitalWrite(P6, LOW);}
else if (header.indexOf("GET /8/on") >= 0) {relay8state = "on";pcf8574_R1.digitalWrite(P7, LOW);}
else if (header.indexOf("GET /9/on") >= 0) {relay9state = "on";pcf8574_R2.digitalWrite(P0, LOW);}
else if (header.indexOf("GET /10/on") >= 0) {relay10state = "on";pcf8574_R2.digitalWrite(P1, LOW);}
else if (header.indexOf("GET /11/on") >= 0) {relay11state = "on";pcf8574_R2.digitalWrite(P2, LOW);}
else if (header.indexOf("GET /12/on") >= 0) {relay12state = "on";pcf8574_R2.digitalWrite(P3, LOW);}
else if (header.indexOf("GET /13/on") >= 0) {relay13state = "on";pcf8574_R2.digitalWrite(P4, LOW);}
else if (header.indexOf("GET /14/on") >= 0) {relay14state = "on";pcf8574_R2.digitalWrite(P5, LOW);}
else if (header.indexOf("GET /15/on") >= 0) {relay15state = "on";pcf8574_R2.digitalWrite(P6, LOW);}
else if (header.indexOf("GET /16/on") >= 0) {relay16state = "on";pcf8574_R2.digitalWrite(P7, LOW);}
/* else if (header.indexOf("GET /17/on") >= 0) {relay17state = "on";pcf8574_R3.digitalWrite(P0, LOW);}
else if (header.indexOf("GET /17/off") >= 0) {relay17state = "off";pcf8574_R3.digitalWrite(P0, HIGH);}
else if (header.indexOf("GET /18/on") >= 0) {relay18state = "on";pcf8574_R3.digitalWrite(P1, LOW);}
else if (header.indexOf("GET /18/off") >= 0) {relay18state = "off";pcf8574_R3.digitalWrite(P1, HIGH);}
else if (header.indexOf("GET /19/on") >= 0) {relay19state = "on";pcf8574_R3.digitalWrite(P2, LOW);}
else if (header.indexOf("GET /19/off") >= 0) {relay19state = "off";pcf8574_R3.digitalWrite(P2, HIGH);}
else if (header.indexOf("GET /20/on") >= 0) {relay20state = "on";pcf8574_R3.digitalWrite(P3, LOW);}
else if (header.indexOf("GET /20/off") >= 0) {relay20state = "off";pcf8574_R3.digitalWrite(P3, HIGH);}
else if (header.indexOf("GET /21/on") >= 0) {relay21state = "on";pcf8574_R3.digitalWrite(P4, LOW);}
else if (header.indexOf("GET /21/off") >= 0) {relay21state = "off";pcf8574_R3.digitalWrite(P4, HIGH);}
else if (header.indexOf("GET /22/on") >= 0) {relay22state = "on";pcf8574_R3.digitalWrite(P5, LOW);}
else if (header.indexOf("GET /22/off") >= 0) {relay22state = "off";pcf8574_R3.digitalWrite(P5, HIGH);}
else if (header.indexOf("GET /23/on") >= 0) {relay23state = "on";pcf8574_R3.digitalWrite(P6, LOW);}
else if (header.indexOf("GET /23/off") >= 0) {relay23state = "off";pcf8574_R3.digitalWrite(P6, HIGH);}
else if (header.indexOf("GET /24/on") >= 0) {relay24state = "on";pcf8574_R3.digitalWrite(P7, LOW);}
else if (header.indexOf("GET /24/off") >= 0) {relay24state = "off";pcf8574_R3.digitalWrite(P7, HIGH);}
else if (header.indexOf("GET /25/on") >= 0) {relay25state = "on";pcf8574_R4.digitalWrite(P0, LOW);}
else if (header.indexOf("GET /25/off") >= 0) {relay25state = "off";pcf8574_R4.digitalWrite(P0, HIGH);}
else if (header.indexOf("GET /26/on") >= 0) {relay26state = "on";pcf8574_R4.digitalWrite(P1, LOW);}
else if (header.indexOf("GET /26/off") >= 0) {relay26state = "off";pcf8574_R4.digitalWrite(P1, HIGH);}
else if (header.indexOf("GET /27/on") >= 0) {relay27state = "on";pcf8574_R4.digitalWrite(P2, LOW);}
else if (header.indexOf("GET /27/off") >= 0) {relay27state = "off";pcf8574_R4.digitalWrite(P2, HIGH);}
else if (header.indexOf("GET /28/on") >= 0) {relay28state = "on";pcf8574_R4.digitalWrite(P3, LOW);}
else if (header.indexOf("GET /28/off") >= 0) {relay28state = "off";pcf8574_R4.digitalWrite(P3, HIGH);}
else if (header.indexOf("GET /29/on") >= 0) {relay29state = "on";pcf8574_R4.digitalWrite(P4, LOW);}
else if (header.indexOf("GET /29/off") >= 0) {relay29state = "off";pcf8574_R4.digitalWrite(P4, HIGH);}
else if (header.indexOf("GET /30/on") >= 0) {relay30state = "on";pcf8574_R4.digitalWrite(P5, LOW);}
else if (header.indexOf("GET /30/off") >= 0) {relay30state = "off";pcf8574_R4.digitalWrite(P5, HIGH);}
else if (header.indexOf("GET /31/on") >= 0) {relay31state = "on";pcf8574_R4.digitalWrite(P6, LOW);}
else if (header.indexOf("GET /31/off") >= 0) {relay31state = "off";pcf8574_R4.digitalWrite(P6, HIGH);}
else if (header.indexOf("GET /32/on") >= 0) {relay32state = "on";pcf8574_R4.digitalWrite(P7, LOW);}
else if (header.indexOf("GET /32/off") >= 0) {relay32state = "off";pcf8574_R4.digitalWrite(P7, HIGH);}*/
relay17state = "on";// state of relay17
relay18state = "on";// state of relay18
relay19state = "on";// state of relay19
relay20state = "on";// state of relay20
relay21state = "on";// state of relay21
relay22state = "on";// state of relay22
relay23state = "on";// state of relay23
relay24state = "on";// state of relay24
relay25state = "on";// state of relay25
relay26state = "on";// state of relay26
relay27state = "on";// state of relay27
relay28state = "on";// state of relay28
relay29state = "on";// state of relay29
relay30state = "on";// state of relay30
relay31state = "on";// state of relay31
relay32state = "on";// state of relay32*/
pcf8574_R1.digitalWrite(P0, LOW);
pcf8574_R4.digitalWrite(P7, LOW);*/
relay17state = "off";// state of relay17
relay18state = "off";// state of relay18
relay19state = "off";// state of relay19
relay20state = "off";// state of relay20
relay21state = "off";// state of relay21
relay22state = "off";// state of relay22
relay23state = "off";// state of relay23
relay24state = "off";// state of relay24
relay25state = "off";// state of relay25
relay26state = "off";// state of relay26
relay27state = "off";// state of relay27
relay28state = "off";// state of relay28
relay29state = "off";// state of relay29
relay30state = "off";// state of relay30
relay31state = "off";// state of relay31
pcf8574_R4.digitalWrite(P7, HIGH); */
client.print("<!DOCTYPE HTML>\r\n");
client.print("<html>\r\n");
client.println("<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}");
client.println(".button { background-color: #195B6A; border: none; color: white; padding: 16px 40px;");
client.println("text-decoration: none; font-size: 30px; margin: 2px; cursor: pointer;}");
if (flag_read_di==1)
client.println(" relay1:" + relay1state + " relay2:" + relay2state + " relay3:" + relay3state + " relay4:" + relay4state + " relay5:" + relay5state + " relay6:" + relay6state + " relay7:" + relay7state + " relay8:" + relay8state + " relay9:" + relay9state + " relay10:" + relay10state + " relay11:" + relay11state + " relay12:" + relay12state + " relay13:" + relay13state + " relay14:" + relay14state + " relay15:" + relay15state + " relay16:" + relay16state );
else
// Web Page Heading
client.println("<body><h1>KC868-A16 Ethernet Web Server</h1>");
if (relay1state == "off") client.println("<a href=\"/1/on\"><button class=\"button\">1-ON</button></a>"); else client.println("<a href=\"/1/off\"><button class=\"button\">1-OFF</button></a>");
if (relay2state == "off") client.println("<a href=\"/2/on\"><button class=\"button\">2-ON</button></a>"); else client.println("<a href=\"/2/off\"><button class=\"button\">2-OFF</button></a>");
if (relay3state == "off") client.println("<a href=\"/3/on\"><button class=\"button\">3-ON</button></a>"); else client.println("<a href=\"/3/off\"><button class=\"button\">3-OFF</button></a>");
if (relay4state == "off") client.println("<a href=\"/4/on\"><button class=\"button\">4-ON</button></a>"); else client.println("<a href=\"/4/off\"><button class=\"button\">4-OFF</button></a>");
if (relay5state == "off") client.println("<a href=\"/5/on\"><button class=\"button\">5-ON</button></a>"); else client.println("<a href=\"/5/off\"><button class=\"button\">5-OFF</button></a>");
if (relay6state == "off") client.println("<a href=\"/6/on\"><button class=\"button\">6-ON</button></a>"); else client.println("<a href=\"/6/off\"><button class=\"button\">6-OFF</button></a>");
if (relay7state == "off") client.println("<a href=\"/7/on\"><button class=\"button\">7-ON</button></a>"); else client.println("<a href=\"/7/off\"><button class=\"button\">7-OFF</button></a>");
if (relay8state == "off") client.println("<a href=\"/8/on\"><button class=\"button\">8-ON</button></a>"); else client.println("<a href=\"/8/off\"><button class=\"button\">8-OFF</button></a>");
if (relay9state == "off") client.println("<a href=\"/9/on\"><button class=\"button\">9-ON</button></a>"); else client.println("<a href=\"/9/off\"><button class=\"button\">9-OFF</button></a>");
if (relay10state == "off") client.println("<a href=\"/10/on\"><button class=\"button\">10-ON</button></a>"); else client.println("<a href=\"/10/off\"><button class=\"button\">10-OFF</button></a>");
if (relay11state == "off") client.println("<a href=\"/11/on\"><button class=\"button\">11-ON</button></a>"); else client.println("<a href=\"/11/off\"><button class=\"button\">11-OFF</button></a>");
if (relay12state == "off") client.println("<a href=\"/12/on\"><button class=\"button\">12-ON</button></a>"); else client.println("<a href=\"/12/off\"><button class=\"button\">12-OFF</button></a>");
if (relay13state == "off") client.println("<a href=\"/13/on\"><button class=\"button\">13-ON</button></a>"); else client.println("<a href=\"/13/off\"><button class=\"button\">13-OFF</button></a>");
if (relay14state == "off") client.println("<a href=\"/14/on\"><button class=\"button\">14-ON</button></a>"); else client.println("<a href=\"/14/off\"><button class=\"button\">14-OFF</button></a>");
if (relay15state == "off") client.println("<a href=\"/15/on\"><button class=\"button\">15-ON</button></a>"); else client.println("<a href=\"/15/off\"><button class=\"button\">15-OFF</button></a>");
if (relay16state == "off") client.println("<a href=\"/16/on\"><button class=\"button\">16-ON</button></a>"); else client.println("<a href=\"/16/off\"><button class=\"button\">16-OFF</button></a>");
/* if (relay17state == "off") client.println("<a href=\"/17/on\"><button class=\"button\">17-ON</button></a>"); else client.println("<a href=\"/17/off\"><button class=\"button\">17-OFF</button></a>");
if (relay18state == "off") client.println("<a href=\"/18/on\"><button class=\"button\">18-ON</button></a>"); else client.println("<a href=\"/18/off\"><button class=\"button\">18-OFF</button></a>");
if (relay19state == "off") client.println("<a href=\"/19/on\"><button class=\"button\">19-ON</button></a>"); else client.println("<a href=\"/19/off\"><button class=\"button\">19-OFF</button></a>");
if (relay20state == "off") client.println("<a href=\"/20/on\"><button class=\"button\">20-ON</button></a>"); else client.println("<a href=\"/20/off\"><button class=\"button\">20-OFF</button></a>");
if (relay21state == "off") client.println("<a href=\"/21/on\"><button class=\"button\">21-ON</button></a>"); else client.println("<a href=\"/21/off\"><button class=\"button\">21-OFF</button></a>");
if (relay22state == "off") client.println("<a href=\"/22/on\"><button class=\"button\">22-ON</button></a>"); else client.println("<a href=\"/22/off\"><button class=\"button\">22-OFF</button></a>");
if (relay23state == "off") client.println("<a href=\"/23/on\"><button class=\"button\">23-ON</button></a>"); else client.println("<a href=\"/23/off\"><button class=\"button\">23-OFF</button></a>");
if (relay24state == "off") client.println("<a href=\"/24/on\"><button class=\"button\">24-ON</button></a>"); else client.println("<a href=\"/24/off\"><button class=\"button\">24-OFF</button></a>");
if (relay25state == "off") client.println("<a href=\"/25/on\"><button class=\"button\">25-ON</button></a>"); else client.println("<a href=\"/25/off\"><button class=\"button\">25-OFF</button></a>");
if (relay26state == "off") client.println("<a href=\"/26/on\"><button class=\"button\">26-ON</button></a>"); else client.println("<a href=\"/26/off\"><button class=\"button\">26-OFF</button></a>");
if (relay27state == "off") client.println("<a href=\"/27/on\"><button class=\"button\">27-ON</button></a>"); else client.println("<a href=\"/27/off\"><button class=\"button\">27-OFF</button></a>");
if (relay28state == "off") client.println("<a href=\"/28/on\"><button class=\"button\">28-ON</button></a>"); else client.println("<a href=\"/28/off\"><button class=\"button\">28-OFF</button></a>");
if (relay29state == "off") client.println("<a href=\"/29/on\"><button class=\"button\">29-ON</button></a>"); else client.println("<a href=\"/29/off\"><button class=\"button\">29-OFF</button></a>");
if (relay30state == "off") client.println("<a href=\"/30/on\"><button class=\"button\">30-ON</button></a>"); else client.println("<a href=\"/30/off\"><button class=\"button\">30-OFF</button></a>");
if (relay31state == "off") client.println("<a href=\"/31/on\"><button class=\"button\">31-ON</button></a>"); else client.println("<a href=\"/31/off\"><button class=\"button\">31-OFF</button></a>");
if (relay32state == "off") client.println("<a href=\"/32/on\"><button class=\"button\">32-ON</button></a>"); else client.println("<a href=\"/32/off\"><button class=\"button\">32-OFF</button></a>");
client.println("<a href=\"/all/on\"><button class=\"button\">all ON</button></a>");
client.println("<a href=\"/all/off\"><button class=\"button\">all OFF</button></a>");
client.println();
break;
currentLine = "";
// Clear the header variable
header = "";
// Close the connection
client.stop();
Serial.println("");
flag_read_di=0;
ScanKey(); //scan key
void ScanKey()
if(pcf8574_I1.digitalRead(P0) == LOW) //key1 pressed
delay(20); //anti-interference
if(pcf8574_I1.digitalRead(P0) == LOW) //key1 pressed again
pcf8574_R1.digitalWrite(P0,!pcf8574_R1.digitalRead(P0)); // toggle relay1 state
while(pcf8574_I1.digitalRead(P0) == LOW); //wait remove hand
if (pcf8574_R1.digitalRead(P0) == LOW) relay1state= "on"; else relay1state= "off";
if(pcf8574_I1.digitalRead(P1) == LOW) //key2 pressed
if(pcf8574_I1.digitalRead(P1) == LOW) //key2 pressed again
pcf8574_R1.digitalWrite(P1,!pcf8574_R1.digitalRead(P1)); // toggle relay2 state
while(pcf8574_I1.digitalRead(P1) == LOW); //wait remove hand
if (pcf8574_R1.digitalRead(P1) == LOW) relay2state= "on"; else relay1state= "off";
if(pcf8574_I1.digitalRead(P2) == LOW) //key3 pressed
if(pcf8574_I1.digitalRead(P2) == LOW) //key3 pressed again
pcf8574_R1.digitalWrite(P2,!pcf8574_R1.digitalRead(P2)); // toggle relay3 state
while(pcf8574_I1.digitalRead(P2) == LOW); //wait remove hand
if (pcf8574_R1.digitalRead(P2) == LOW) relay3state= "on"; else relay1state= "off";
if(pcf8574_I1.digitalRead(P3) == LOW) //key4 pressed
if(pcf8574_I1.digitalRead(P3) == LOW) //key4 pressed again
pcf8574_R1.digitalWrite(P3,!pcf8574_R1.digitalRead(P3)); // toggle relay4 state
while(pcf8574_I1.digitalRead(P3) == LOW); //wait remove hand
if (pcf8574_R1.digitalRead(P3) == LOW) relay4state= "on"; else relay1state= "off";
if(pcf8574_I1.digitalRead(P4) == LOW) //key5 pressed
if(pcf8574_I1.digitalRead(P4) == LOW) //key5 pressed again
pcf8574_R1.digitalWrite(P4,!pcf8574_R1.digitalRead(P4)); // toggle relay5 state
while(pcf8574_I1.digitalRead(P4) == LOW); //wait remove hand
if (pcf8574_R1.digitalRead(P4) == LOW) relay5state= "on"; else relay1state= "off";
if(pcf8574_I1.digitalRead(P5) == LOW) //key6 pressed
if(pcf8574_I1.digitalRead(P5) == LOW) //key6 pressed again
pcf8574_R1.digitalWrite(P5,!pcf8574_R1.digitalRead(P5)); // toggle relay6 state
while(pcf8574_I1.digitalRead(P5) == LOW); //wait remove hand
if (pcf8574_R1.digitalRead(P5) == LOW) relay6state= "on"; else relay1state= "off";
if(pcf8574_I1.digitalRead(P6) == LOW) //key7 pressed
if(pcf8574_I1.digitalRead(P6) == LOW) //key7 pressed again
pcf8574_R1.digitalWrite(P6,!pcf8574_R1.digitalRead(P6)); // toggle relay7 state
while(pcf8574_I1.digitalRead(P6) == LOW); //wait remove hand
if (pcf8574_R1.digitalRead(P6) == LOW) relay7state= "on"; else relay1state= "off";
if(pcf8574_I1.digitalRead(P7) == LOW) //key8 pressed
if(pcf8574_I1.digitalRead(P7) == LOW) //key8 pressed again
pcf8574_R1.digitalWrite(P7,!pcf8574_R1.digitalRead(P7)); // toggle relay8 state
while(pcf8574_I1.digitalRead(P7) == LOW); //wait remove hand
if (pcf8574_R1.digitalRead(P7) == LOW) relay8state= "on"; else relay1state= "off";
if(pcf8574_I2.digitalRead(P0) == LOW) //key9 pressed
if(pcf8574_I2.digitalRead(P0) == LOW) //key9 pressed again
pcf8574_R2.digitalWrite(P0,!pcf8574_R2.digitalRead(P0)); // toggle relay9 state
while(pcf8574_I2.digitalRead(P0) == LOW); //wait remove hand
if (pcf8574_R2.digitalRead(P0) == LOW) relay9state= "on"; else relay1state= "off";
if(pcf8574_I2.digitalRead(P1) == LOW) //key10 pressed
if(pcf8574_I2.digitalRead(P1) == LOW) //key10 pressed again
pcf8574_R2.digitalWrite(P1,!pcf8574_R2.digitalRead(P1)); // toggle relay10 state
while(pcf8574_I2.digitalRead(P1) == LOW); //wait remove hand
if (pcf8574_R2.digitalRead(P1) == LOW) relay10state= "on"; else relay1state= "off";
if(pcf8574_I2.digitalRead(P2) == LOW) //key11 pressed
if(pcf8574_I2.digitalRead(P2) == LOW) //key11 pressed again
pcf8574_R2.digitalWrite(P2,!pcf8574_R2.digitalRead(P2)); // toggle relay11 state
while(pcf8574_I2.digitalRead(P2) == LOW); //wait remove hand
if (pcf8574_R2.digitalRead(P2) == LOW) relay11state= "on"; else relay1state= "off";
if(pcf8574_I2.digitalRead(P3) == LOW) //key12 pressed
if(pcf8574_I2.digitalRead(P3) == LOW) //key12 pressed again
pcf8574_R2.digitalWrite(P3,!pcf8574_R2.digitalRead(P3)); // toggle relay12 state
while(pcf8574_I2.digitalRead(P3) == LOW); //wait remove hand
if (pcf8574_R2.digitalRead(P3) == LOW) relay12state= "on"; else relay1state= "off";
if(pcf8574_I2.digitalRead(P4) == LOW) //key13 pressed
if(pcf8574_I2.digitalRead(P4) == LOW) //key13 pressed again
pcf8574_R2.digitalWrite(P4,!pcf8574_R2.digitalRead(P4)); // toggle relay13 state
while(pcf8574_I2.digitalRead(P4) == LOW); //wait remove hand
if (pcf8574_R2.digitalRead(P4) == LOW) relay13state= "on"; else relay1state= "off";
if(pcf8574_I2.digitalRead(P5) == LOW) //key14 pressed
if(pcf8574_I2.digitalRead(P5) == LOW) //key14 pressed again
pcf8574_R2.digitalWrite(P5,!pcf8574_R2.digitalRead(P5)); // toggle relay14 state
while(pcf8574_I2.digitalRead(P5) == LOW); //wait remove hand
if (pcf8574_R2.digitalRead(P5) == LOW) relay14state= "on"; else relay1state= "off";
if(pcf8574_I2.digitalRead(P6) == LOW) //key15 pressed
if(pcf8574_I2.digitalRead(P6) == LOW) //key15 pressed again
pcf8574_R2.digitalWrite(P6,!pcf8574_R2.digitalRead(P6)); // toggle relay15 state
while(pcf8574_I2.digitalRead(P6) == LOW); //wait remove hand
if (pcf8574_R2.digitalRead(P6) == LOW) relay15state= "on"; else relay1state= "off";
if(pcf8574_I2.digitalRead(P7) == LOW) //key16 pressed
if(pcf8574_I2.digitalRead(P7) == LOW) //key16 pressed again
pcf8574_R2.digitalWrite(P7,!pcf8574_R2.digitalRead(P7)); // toggle relay16 state
while(pcf8574_I2.digitalRead(P7) == LOW); //wait remove hand
if (pcf8574_R2.digitalRead(P7) == LOW) relay16state= "on"; else relay1state= "off";
if(pcf8574_I3.digitalRead(P0) == LOW) //key17 pressed
if(pcf8574_I3.digitalRead(P0) == LOW) //key17 pressed again
pcf8574_R3.digitalWrite(P0,!pcf8574_R3.digitalRead(P0)); // toggle relay17 state
while(pcf8574_I3.digitalRead(P0) == LOW); //wait remove hand
if (pcf8574_R3.digitalRead(P0) == LOW) relay17state= "on"; else relay1state= "off";
if(pcf8574_I3.digitalRead(P1) == LOW) //key18 pressed
if(pcf8574_I3.digitalRead(P1) == LOW) //key18 pressed again
pcf8574_R3.digitalWrite(P1,!pcf8574_R3.digitalRead(P1)); // toggle relay18 state
while(pcf8574_I3.digitalRead(P1) == LOW); //wait remove hand
if (pcf8574_R3.digitalRead(P1) == LOW) relay18state= "on"; else relay1state= "off";
if(pcf8574_I3.digitalRead(P2) == LOW) //key19 pressed
if(pcf8574_I3.digitalRead(P2) == LOW) //key19 pressed again
pcf8574_R3.digitalWrite(P2,!pcf8574_R3.digitalRead(P2)); // toggle relay19 state
while(pcf8574_I3.digitalRead(P2) == LOW); //wait remove hand
if (pcf8574_R3.digitalRead(P2) == LOW) relay19state= "on"; else relay1state= "off";
if(pcf8574_I3.digitalRead(P3) == LOW) //key20 pressed
if(pcf8574_I3.digitalRead(P3) == LOW) //key20 pressed again
pcf8574_R3.digitalWrite(P3,!pcf8574_R3.digitalRead(P3)); // toggle relay20 state
while(pcf8574_I3.digitalRead(P3) == LOW); //wait remove hand
if (pcf8574_R3.digitalRead(P3) == LOW) relay20state= "on"; else relay1state= "off";
if(pcf8574_I3.digitalRead(P4) == LOW) //key21 pressed
if(pcf8574_I3.digitalRead(P4) == LOW) //key21 pressed again
pcf8574_R3.digitalWrite(P4,!pcf8574_R3.digitalRead(P4)); // toggle relay21 state
while(pcf8574_I3.digitalRead(P4) == LOW); //wait remove hand
if (pcf8574_R3.digitalRead(P4) == LOW) relay21state= "on"; else relay1state= "off";
if(pcf8574_I3.digitalRead(P5) == LOW) //key22 pressed
if(pcf8574_I3.digitalRead(P5) == LOW) //key22 pressed again
pcf8574_R3.digitalWrite(P5,!pcf8574_R3.digitalRead(P5)); // toggle relay22 state
while(pcf8574_I3.digitalRead(P5) == LOW); //wait remove hand
if (pcf8574_R3.digitalRead(P5) == LOW) relay22state= "on"; else relay1state= "off";
if(pcf8574_I3.digitalRead(P6) == LOW) //key23 pressed
if(pcf8574_I3.digitalRead(P6) == LOW) //key23 pressed again
pcf8574_R3.digitalWrite(P6,!pcf8574_R3.digitalRead(P6)); // toggle relay23 state
while(pcf8574_I3.digitalRead(P6) == LOW); //wait remove hand
if (pcf8574_R3.digitalRead(P6) == LOW) relay23state= "on"; else relay1state= "off";
if(pcf8574_I3.digitalRead(P7) == LOW) //key24 pressed
if(pcf8574_I3.digitalRead(P7) == LOW) //key24 pressed again
pcf8574_R3.digitalWrite(P7,!pcf8574_R3.digitalRead(P7)); // toggle relay24 state
while(pcf8574_I3.digitalRead(P7) == LOW); //wait remove hand
if (pcf8574_R3.digitalRead(P7) == LOW) relay24state= "on"; else relay1state= "off";
if(pcf8574_I4.digitalRead(P0) == LOW) //key25 pressed
if(pcf8574_I4.digitalRead(P0) == LOW) //key25 pressed again
pcf8574_R4.digitalWrite(P0,!pcf8574_R4.digitalRead(P0)); // toggle relay25 state
while(pcf8574_I4.digitalRead(P0) == LOW); //wait remove hand
if (pcf8574_R4.digitalRead(P0) == LOW) relay25state= "on"; else relay1state= "off";
if(pcf8574_I4.digitalRead(P1) == LOW) //key26 pressed
if(pcf8574_I4.digitalRead(P1) == LOW) //key26 pressed again
pcf8574_R4.digitalWrite(P1,!pcf8574_R4.digitalRead(P1)); // toggle relay26 state
while(pcf8574_I4.digitalRead(P1) == LOW); //wait remove hand
if (pcf8574_R4.digitalRead(P1) == LOW) relay26state= "on"; else relay1state= "off";
if(pcf8574_I4.digitalRead(P2) == LOW) //key27 pressed
if(pcf8574_I4.digitalRead(P2) == LOW) //key27 pressed again
pcf8574_R4.digitalWrite(P2,!pcf8574_R4.digitalRead(P2)); // toggle relay27 state
while(pcf8574_I4.digitalRead(P2) == LOW); //wait remove hand
if (pcf8574_R4.digitalRead(P2) == LOW) relay27state= "on"; else relay1state= "off";
if(pcf8574_I4.digitalRead(P3) == LOW) //key28 pressed
if(pcf8574_I4.digitalRead(P3) == LOW) //key28 pressed again
pcf8574_R4.digitalWrite(P3,!pcf8574_R4.digitalRead(P3)); // toggle relay28 state
while(pcf8574_I4.digitalRead(P3) == LOW); //wait remove hand
if (pcf8574_R4.digitalRead(P3) == LOW) relay28state= "on"; else relay1state= "off";
if(pcf8574_I4.digitalRead(P4) == LOW) //key29 pressed
if(pcf8574_I4.digitalRead(P4) == LOW) //key29 pressed again
pcf8574_R4.digitalWrite(P4,!pcf8574_R4.digitalRead(P4)); // toggle relay29 state
while(pcf8574_I4.digitalRead(P4) == LOW); //wait remove hand
if (pcf8574_R4.digitalRead(P4) == LOW) relay29state= "on"; else relay1state= "off";
if(pcf8574_I4.digitalRead(P5) == LOW) //key30 pressed
if(pcf8574_I4.digitalRead(P5) == LOW) //key30 pressed again
pcf8574_R4.digitalWrite(P5,!pcf8574_R4.digitalRead(P5)); // toggle relay30 state
while(pcf8574_I4.digitalRead(P5) == LOW); //wait remove hand
if (pcf8574_R4.digitalRead(P5) == LOW) relay30state= "on"; else relay1state= "off";
if(pcf8574_I4.digitalRead(P6) == LOW) //key31 pressed
if(pcf8574_I4.digitalRead(P6) == LOW) //key31 pressed again
pcf8574_R4.digitalWrite(P6,!pcf8574_R4.digitalRead(P6)); // toggle relay31 state
while(pcf8574_I4.digitalRead(P6) == LOW); //wait remove hand
if (pcf8574_R4.digitalRead(P6) == LOW) relay31state= "on"; else relay1state= "off";
if(pcf8574_I4.digitalRead(P7) == LOW) //key32 pressed
if(pcf8574_I4.digitalRead(P7) == LOW) //key32 pressed again
pcf8574_R4.digitalWrite(P7,!pcf8574_R4.digitalRead(P7)); // toggle relay32 state
while(pcf8574_I4.digitalRead(P7) == LOW); //wait remove hand
if (pcf8574_R4.digitalRead(P7) == LOW) relay32state= "on"; else relay1state= "off";
