10-08-2024, 01:51 AM
here we use RS485 long distance sensor connect with A32 Pro controller using A and B.
the sensor default setting is 9600bps, RS485 address is 1
we can use USB-RS485 adapter connect PC with sensor , monitor the sensor value, or maybe you want change the sensor address and baud rate, so just use PC software to set. Then we can let sensor connect to A32 Pro's RS485 port directly.
mainly add these code for modbus:
uart:
- id: uart_modbus
baud_rate: 9600
tx_pin: 9
rx_pin: 8
# Config Modbus
modbus:
uart_id: uart_modbus
modbus_controller:
- id: modbus_sensor
address: 0x01 # device address
modbus_id: modbus1
- platform: modbus_controller
modbus_controller_id: modbus_sensor
name: "RS485 Temperature Sensor"
address: 0x0000
register_type: holding
value_type: U_WORD
unit_of_measurement: "°C"
accuracy_decimals: 1
filters:
- lambda: if (x < 10000) return x * 0.1; else return -1 * (x - 10000) * 0.1;
name: "RS485 Humidity Sensor"
address: 0x0001
value_type: U_WORD
unit_of_measurement: "%"
filters:
- multiply: 0.1
whole ESPHome ymal code:
friendly_name: a32-Pro-arduino
platformio_options:
board_build.extra_flags:
# WIFI_CONTROL_SELF_MODE = 0
# WIFI_CONTROL_SELF_MODE = 1
- "-DWIFI_CONTROL_SELF_MODE=0"
external_components:
- source:
type: git
ref: v1.2.0
board: esp32-s3-devkitc-1
type: arduino
# logger:
encryption:
key: "fBpihEYPVlfKaE4ZIcY0uRcJ134u7DBKzzskk994+Lw="
type: W5500
clk_pin: GPIO42
mosi_pin: GPIO44
miso_pin: GPIO40
cs_pin: GPIO39
interrupt_pin: GPIO41
reset_pin: GPIO43
uart:
- id: uart_modbus
baud_rate: 9600
tx_pin: 9
rx_pin: 8
- id: tuya_mcu_uart
baud_rate: 9600
tx_pin: 15
rx_pin: 16
tuya_wifi_mcu:
# tuya mcu product id
product_id: fwy7fk4mzay3kern
uart_id: tuya_mcu_uart
wifi_reset_pin: 21
wifi_led_pin: 45
# Config Modbus
modbus:
modbus_controller:
- id: modbus_sensor
modbus_id: modbus1
- id: bus_a
sda: 11
scl: 10
frequency: 400kHz
xl9535:
- id: xl9535_hub_out1 # for output channel 1-16
address: 0x21
- id: xl9535_hub_out2 # for output channel 17-32
address: 0x22
- id: xl9535_hub_in1 # for input channel 1-16
address: 0x24
- id: xl9535_hub_in2 # for input channel 17-32
address: 0x25
- id: 'pcf8574_in_3' # for input channel 33-40
address: 0x23
pin: 45
name: A32 Pro Switch01
xl9535: xl9535_hub_out1
mode: OUTPUT
- platform: tuya_wifi_mcu
name: A32 Pro Switch01 Tuya
dp_id: 101
# hide from homeassistant ui
internal: true
bind_switch_id: "a32_pro_switch01"
name: A32 Pro Switch02
mode: OUTPUT
name: A32 Pro Switch02 Tuya
dp_id: 102
internal: true
bind_switch_id: "a32_pro_switch02"
name: A32 Pro Switch03
mode: OUTPUT
name: A32 Pro Switch03 Tuya
dp_id: 103
internal: true
bind_switch_id: "a32_pro_switch03"
name: A32 Pro Switch04
mode: OUTPUT
name: A32 Pro Switch04 Tuya
dp_id: 104
internal: true
bind_switch_id: "a32_pro_switch04"
name: A32 Pro Switch05
number: 4
mode: OUTPUT
name: A32 Pro Switch05 Tuya
dp_id: 105
internal: true
bind_switch_id: "a32_pro_switch05"
name: A32 Pro Switch06
number: 5
mode: OUTPUT
name: A32 Pro Switch06 Tuya
dp_id: 106
internal: true
bind_switch_id: "a32_pro_switch06"
name: A32 Pro Switch07
number: 6
mode: OUTPUT
name: A32 Pro Switch07 Tuya
dp_id: 107
internal: true
bind_switch_id: "a32_pro_switch07"
name: A32 Pro Switch08
number: 7
mode: OUTPUT
name: A32 Pro Switch08 Tuya
dp_id: 108
internal: true
bind_switch_id: "a32_pro_switch08"
name: A32 Pro Switch09
number: 10
mode: OUTPUT
name: A32 Pro Switch09 Tuya
dp_id: 109
internal: true
bind_switch_id: "a32_pro_switch09"
name: A32 Pro Switch10
number: 11
mode: OUTPUT
name: A32 Pro Switch10 Tuya
dp_id: 110
internal: true
bind_switch_id: "a32_pro_switch10"
name: A32 Pro Switch11
number: 12
mode: OUTPUT
name: A32 Pro Switch11 Tuya
dp_id: 111
internal: true
bind_switch_id: "a32_pro_switch11"
name: A32 Pro Switch12
number: 13
mode: OUTPUT
name: A32 Pro Switch12 Tuya
dp_id: 112
internal: true
bind_switch_id: "a32_pro_switch12"
name: A32 Pro Switch13
number: 14
mode: OUTPUT
name: A32 Pro Switch13 Tuya
dp_id: 113
internal: true
bind_switch_id: "a32_pro_switch13"
name: A32 Pro Switch14
number: 15
mode: OUTPUT
name: A32 Pro Switch14 Tuya
dp_id: 114
internal: true
bind_switch_id: "a32_pro_switch14"
name: A32 Pro Switch15
number: 16
mode: OUTPUT
name: A32 Pro Switch15 Tuya
dp_id: 115
internal: true
bind_switch_id: "a32_pro_switch15"
name: A32 Pro Switch16
number: 17
mode: OUTPUT
name: A32 Pro Switch16 Tuya
dp_id: 116
internal: true
bind_switch_id: "a32_pro_switch16"
name: A32 Pro Switch17
xl9535: xl9535_hub_out2
mode: OUTPUT
name: A32 Pro Switch17 Tuya
dp_id: 117
internal: true
bind_switch_id: "a32_pro_switch17"
name: A32 Pro Switch18
mode: OUTPUT
name: A32 Pro Switch18 Tuya
dp_id: 118
internal: true
bind_switch_id: "a32_pro_switch18"
name: A32 Pro Switch19
mode: OUTPUT
name: A32 Pro Switch19 Tuya
dp_id: 119
internal: true
bind_switch_id: "a32_pro_switch19"
name: A32 Pro Switch20
mode: OUTPUT
name: A32 Pro Switch20 Tuya
dp_id: 120
internal: true
bind_switch_id: "a32_pro_switch20"
name: A32 Pro Switch21
number: 4
mode: OUTPUT
name: A32 Pro Switch21 Tuya
dp_id: 121
internal: true
bind_switch_id: "a32_pro_switch21"
name: A32 Pro Switch22
number: 5
mode: OUTPUT
name: A32 Pro Switch22 Tuya
dp_id: 122
internal: true
bind_switch_id: "a32_pro_switch22"
name: A32 Pro Switch23
number: 6
mode: OUTPUT
name: A32 Pro Switch23 Tuya
dp_id: 123
internal: true
bind_switch_id: "a32_pro_switch23"
name: A32 Pro Switch24
number: 7
mode: OUTPUT
name: A32 Pro Switch24 Tuya
dp_id: 124
internal: true
bind_switch_id: "a32_pro_switch24"
name: A32 Pro Switch25
number: 10
mode: OUTPUT
name: A32 Pro Switch25 Tuya
dp_id: 125
internal: true
bind_switch_id: "a32_pro_switch25"
name: A32 Pro Switch26
number: 11
mode: OUTPUT
name: A32 Pro Switch26 Tuya
dp_id: 126
internal: true
bind_switch_id: "a32_pro_switch26"
name: A32 Pro Switch27
number: 12
mode: OUTPUT
name: A32 Pro Switch27 Tuya
dp_id: 127
internal: true
bind_switch_id: "a32_pro_switch27"
name: A32 Pro Switch28
number: 13
mode: OUTPUT
name: A32 Pro Switch28 Tuya
dp_id: 128
internal: true
bind_switch_id: "a32_pro_switch28"
name: A32 Pro Switch29
number: 14
mode: OUTPUT
name: A32 Pro Switch29 Tuya
dp_id: 129
internal: true
bind_switch_id: "a32_pro_switch29"
name: A32 Pro Switch30
number: 15
mode: OUTPUT
name: A32 Pro Switch30 Tuya
dp_id: 130
internal: true
bind_switch_id: "a32_pro_switch30"
name: A32 Pro Switch31
number: 16
mode: OUTPUT
name: A32 Pro Switch31 Tuya
dp_id: 131
internal: true
bind_switch_id: "a32_pro_switch31"
name: A32 Pro Switch32
number: 17
mode: OUTPUT
name: A32 Pro Switch32 Tuya
dp_id: 132
internal: true
bind_switch_id: "a32_pro_switch32"
name: A32 Pro DI01
on_press:
then:
- switch.toggle: a32_pro_switch01
xl9535: xl9535_hub_in1
name: A32 Pro DI01 Tuya
dp_id: 133
bind_binary_sensor_id: a32_pro_di01
internal: true
name: A32 Pro DI02
name: A32 Pro DI02 Tuya
dp_id: 134
bind_binary_sensor_id: a32_pro_di02
internal: true
name: A32 Pro DI03
name: A32 Pro DI03 Tuya
dp_id: 135
bind_binary_sensor_id: a32_pro_di03
internal: true
name: A32 Pro DI04
name: A32 Pro DI04 Tuya
dp_id: 136
bind_binary_sensor_id: a32_pro_di04
internal: true
name: A32 Pro DI05
number: 4
name: A32 Pro DI06
number: 5
name: A32 Pro DI07
number: 6
name: A32 Pro DI08
number: 7
name: A32 Pro DI09
number: 10
name: A32 Pro DI10
number: 11
name: A32 Pro DI11
number: 12
name: A32 Pro DI12
number: 13
name: A32 Pro DI13
number: 14
name: A32 Pro DI14
number: 15
name: A32 Pro DI15
number: 16
name: A32 Pro DI16
number: 17
name: "A32 Pro TMP1"
name: "A32 Pro TMP2"
name: "A32 Pro DL"
name: "A32 Pro DTUYA"
number: 21
name: A32 Pro DI17
xl9535: xl9535_hub_in2
name: A32 Pro DI18
name: A32 Pro DI19
name: A32 Pro DI20
name: A32 Pro DI21
number: 4
name: A32 Pro DI22
number: 5
name: A32 Pro DI23
number: 6
name: A32 Pro DI24
number: 7
name: A32 Pro DI25
number: 10
name: A32 Pro DI26
number: 11
name: A32 Pro DI27
number: 12
name: A32 Pro DI28
number: 13
name: A32 Pro DI29
number: 14
name: A32 Pro DI30
number: 15
name: A32 Pro DI31
number: 16
name: A32 Pro DI32
number: 17
name: A32 Pro DI33
pcf8574: pcf8574_in_3
name: A32 Pro DI34
name: A32 Pro DI35
name: A32 Pro DI36
name: A32 Pro DI37
number: 4
name: A32 Pro DI38
number: 5
name: A32 Pro DI39
number: 6
name: A32 Pro DI40
number: 7
gp8403:
voltage: 10V
output:
- platform: gp8403
gp8403_id: my_gp8403
channel: 0
- platform: gp8403
channel: 1
light:
- platform: monochromatic
name: "A32 Pro-DAC-0"
output: gp8403_output_1
gamma_correct: 1.0
name: "Tuya A32 Pro-DAC-0"
# bind other light, sync state
bind_light_id: a32_pro_dac_0
dp_id: 173
internal: true
gamma_correct: 1.0
name: "A32 Pro-DAC-1"
output: gp8403_output_2
gamma_correct: 1.0
name: "Tuya A32 Pro-DAC-1"
bind_light_id: a32_pro_dac_1
dp_id: 174
internal: true
gamma_correct: 1.0
- platform: adc
pin: 7
name: "A32 Pro A1 Voltage"
update_interval: 5s
attenuation: 11db
filters:
- lambda:
if (x >= 3.11) {
return x * 1.60256;
} else if (x <= 0.15) {
return 0;
} else {
return x * 1.51;
- platform: adc
pin: 6
name: "A32 Pro A2 Voltage"
update_interval: 5s
attenuation: 11db
filters:
# - multiply: 1.51515
- lambda:
if (x >= 3.11) {
return x * 1.60256;
return 0;
} else {
return x * 1.51;
- platform: adc
pin: 5
name: "A32 Pro A3 Current"
update_interval: 5s
unit_of_measurement: mA
attenuation: 11db
filters:
- multiply: 6.66666666
- platform: adc
pin: 4
name: "A32 Pro A4 Current"
update_interval: 5s
attenuation: 11db
filters:
address: 0x0000
value_type: U_WORD
filters:
address: 0x0001
value_type: U_WORD
filters:
- multiply: 0.1
web_server:
port: 80
font:
- file: "gfonts://Roboto"
display:
- platform: ssd1306_i2c
i2c_id: bus_a
model: "SSD1306 128x64"
address: 0x3C
lambda: |-
it.printf(0, 0, id(roboto), "A32 Pro");
A32_Pro-ESPHome_arduino_type_RS485_MODBUS_SENSOR.txt (Size: 23.44 KB / Downloads: 451)
RS485 sensor config PC software:
RS485-sensor-PC-tool.zip (Size: 4.08 MB / Downloads: 588)
