Threads: 4
I will install on KC868-A16 board as I got it from you guys.
Which antenna is for sender long or short one?
Threads: 3
Hi have installed the send/receive antennas and the modules in my kincony device.
I have not added and configuration for these. However, what I have found is that after I installed the modules it kills my home garage remote. The home garage remote only works when i very close proxymity of the garage door motor (like 12 meters). Anything outside of this range it doesnt work anymore.
If I cut power to the kincony device it works normal again.
So I am wondering if there is any ESPHome configuration to adjust the power of the RF modules?
Thanks
Threads: 1,473
do you use ESPHome or KCS firmware? if you are using ESPHome. maybe you have config the yaml always send RF signal.
Threads: 3
I use ESPHome. No RF configured in ESPHome yet.
my config looks like this:
# Device Specific Config
platform: ESP32
comment: ${device_description}
project:
version: "${project_version}"
time:
- platform: sntp
timezone: XXXXXXXX
servers: !secret sntp_server
on_time_sync:
then:
- logger.log: "Synchronized sntp clock"
web_server:
port: 80
auth:
username: admin
password: !secret web_server_password
include_internal: true
# Configuration entry for ESP32
sda: 4
scl: 5
# Channels configuration
address: 0x24
address: 0x25
address: 0x21
address: 0x22
# Individual inputs
# Uptime Sensor
- platform: uptime
update_interval: 360s
on_raw_value:
then:
- text_sensor.template.publish:
state: !lambda |-
int seconds = round(id(uptime_sensor).raw_state);
int days = seconds / (24 * 3600);
seconds = seconds % (24 * 3600);
int hours = seconds / 3600;
seconds = seconds % 3600;
int minutes = seconds / 60;
seconds = seconds % 60;
return (
(days ? to_string(days) + "d " : "") +
(hours ? to_string(hours) + "h " : "") +
(minutes ? to_string(minutes) + "m " : "") +
(to_string(seconds) + "s")
).c_str();
- platform: template
name: KinKony A16 Internal Temperature
lambda: return temperatureRead();
unit_of_measurement: °C
accuracy_decimals: 2
Threads: 1,473
you can remove the RF sender module from KC868-A16 PCB.
Threads: 3
Yes I know I can - but I want to use it. That is why I am asking how to configure it in ESPHome yaml and adjust the power of it.
