[Arduino IDE demo source code for KC868-A6]--#12-Web_server_code
.zip   KC868-A6_Web_Server.zip (Size: 461.74 KB / Downloads: 1,165)
* Create Your own WebServer for KC868-A6 Smart Controller*
// Load Wi-Fi library
#include <WiFi.h>
#include "PCF8574.h"
#include <WiFiManager.h>
#define TRIGGER_PIN 0   // reset wifi button
WiFiManager wm;
/* const char* ssid     = "xxx"; //your router's ssid
WiFiServer server(80);
String header;
// Current time
// Previous time
int flag_read_di=0;
TwoWire I2Cone = TwoWire(0);
TwoWire I2Ctwo = TwoWire(1);
//set I2C of A6
PCF8574 pcf8574_I1(&I2Cone,0x22,4,15);
PCF8574 pcf8574_R1(&I2Cone,0x24,4,15);
String relaystate[16]={"relay1state","relay2state","relay3state","relay4state",
                       "relay5state","relay6state"
  for(int i=0;i<=5;i++)
  pcf8574_R1.begin();
     pcf8574_I1.pinMode(i, INPUT);
    pcf8574_I1.begin();
    WiFi.mode(WIFI_STA);
     bool res;
       res = wm.autoConnect("KC868-A6-AP"); // anonymous ap
    if(!res) {
    else {
  Serial.println("");
  server.begin();
void loop(){
  WiFiClient client = server.available();   // Listen for incoming clients
    currentTime = millis();
    previousTime = currentTime;
        header += c;
            client.println();
            // turns 16 relays on and off
            // Display the HTML web page
            if (flag_read_di==1)
              client.println(" relay1:" + relay1state + " relay2:" + relay2state + " relay3:" + relay3state + " relay4:" + relay4state + " relay5:" + relay5state + " relay6:" + relay6state);
            else
            // Web Page Heading
            client.println("<body><h1>KC868-A6 Web Server</h1>");
            client.println();
            break;
            currentLine = "";
    // Clear the header variable
    header = "";
    // Close the connection
    client.stop();
    Serial.println("");
    flag_read_di=0;
void ScanKey()
    if(pcf8574_I1.digitalRead(i) == LOW)         //key pressed
        delay(20);
        if(pcf8574_I1.digitalRead(i) == LOW)       //key pressed again
buen dia intento compilar el código y hace todo lo de la conexión pero al final me dice ip 0.0.0.0 y no me deja conectarme a ap 192.168.4.1
Do you have replaced wifi ssid and password in code?
(09-09-2024, 11:05 PM)administración Wrote: ¿Has reemplazado el SSID y la contraseña del wifi en el código?
Si ya lo hice , de hecho use otro codigo para conectarme como cliente web y si funcionó , en el código que ustedes enviaron dice no conectado. Me pueden ayudar por favor , gracias de ante mano
Hi, I got the following error:
exit status 1
Compilation error: no matching function for call to 'PCF8574:TongueCF8574(TwoWire*, int, int, int)'
could you please help in this topic?
Thanks.
you need install PCF8574 arduino library.
download link: https://www.kincony.com/forum/attachment.php?aid=6459
Thank you.
Compiled successfully.
But on the serial monitor i can see this:
���Ƶ���9����� !�*wm:config portal has timed out
*wm:config portal exiting
Failed to connect
WiFi connected.
IP address:
0.0.0.0
is this normal?
do you have replace your router's ssid and password.l
Yes, I added the correct network, but I see this:
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
modeBig GrinIO, clock div:1
load:0x3fff0030,len:4832
load:0x40078000,len:16460
load:0x40080400,len:4
load:0x40080404,len:3504
entry 0x400805cc
*wm:AutoConnect
*wm:No wifi saved, skipping
*wm:AutoConnect: FAILED for  1 ms
*wm:StartAP with SSID:  KC868-A6-AP
*wm:AP IP address: 192.168.4.1
*wm:Starting Web Portal
*wm:28 networks found
Failed to connect
WiFi connected.
IP address:
0.0.0.0
*wm:resetSettings
E (148830) wifi:NAN WiFi stop
*wm:SETTINGS ERASED
ets Jul 29 2019 12:21:46
Shall I join to the kc869 AP?
Ot it is enough that both device is on the same network?
it should work in STA mode. you can also try to download our BIN file directly.
